We are using the community version of onlyoffice, and then we found out that the count of connections for the community version is limited to 20. What can I do to increase the maximum number of connections for the community version? Are the following solutions feasible?
Switch to the enterprise or development version, and then buy connections to increase the maximum number of connections(I sure that can work my question out)
Use the community version, then buy connections to increase the maximum number of connections
Conduct source code development and compilation in the community version, and then increase the maximum number of connections through the code.
Looking forward to your reply. thank you
