Kevin
28 June 2024 07:22
1
Hello
Debian 12.5
ONLYOFFICE Groups Version 12.6.0.1900
I observe an incorrect combination of Projects - Calendars - radicale.
After adding a new project, the calendar for this project in radicale is created ONLY after “Export and sync”.
After deleting a project, its calendar is NOT deleted in radicale.
Unable to delete via CalDav - read only.
The only way to delete is manually in the directory
/var/www/onlyoffice/Data/radicale/collections/collection-root/UserAccount/project_id…
Hello @Kevin
This is expected behavior. Created calendars are not getting shared automatically, hence it is meant to export them in the first place.
Kevin:
We will take a closer look at this situation. I will keep you posted about the results.
We have checked the situation with remaining calendar after deleting project and registered a bug on this behavior - indeed, records are left in mentioned directory. Thank you for the report.
