Hi guys!
I’m having problems integrating Onlyoffice with the latest version of Liferay 7.4.3.6-ga6. Is there any way to integrate it with the latest version of Liferay? or is not supported at the moment?
I was able to install the connector plugin, but i couldn’t install the .jar from onlyoffice docs (I have downloaded it from github repository: https://github.com/ONLYOFFICE/onlyoffice-liferay/releases)
Thanks!
Hello @Duck3000
We know about this issue and we are working on it. The fix is planned for the next version of connector. Meanwhile, workaround solution is using ga1-version.
Sorry for inconvenience.
Thanks for quick answer @Alexandre
do you know when the next version may be released?
It’s a little bit hard to say at the moment. I hope we will finish next Liferay connector version in 4-6 weeks, but timeframes can change.
