Problem with syncing of SENT folder
Hello guys!
I am using a self hosted instance of onlyoffice and I have problems with the mail sync between the app mail client and my server (postfix). So all of the inboxes are synced correctly but my ask is: is there a way how sent mails through the web client of onlyoffice to be automatically copied to the sent dir of my IMAP Sent folder?
I would like to sync all of send emails from my desktop mail clients (outlook, thunderbird) with the send mails from onlyoffice web client…
Hello guybo.
Please check it out: ONLYOFFICE Mail. How it works - ONLYOFFICE
Your scenario (sync Sent folder) should work. “None of the actions performed in our client are transferred to the source server, with the only exception: a sent message is placed to the “Sent” folder on the server.”
Could you please provide us with detail about your installation (OS, guide which you used, component versions). Also please double check that issue scenario is correct. Probably sync works, but with a delay?
used installation guide - method 1 from:
https://helpcenter.onlyoffice.com/installation/workspace-install-linux.aspx
OS: CentOS Linux release 7.9.2009 (Core)
Sync still does not work for the sent emails through the web client
Could you please provide us with whole Community server logs folder? It’s located here: /var/log/onlyoffice/
