Problem with mysql repositories installing on Ubuntu 24.04 (no docker version)
DocSpace version:
Type of installation of the DocSpace: deb, official installation guide
OS: Ubuntu 24.04
When I want to install docspace on Ubuntu 24.04 it gives an error with the mysql repository, since it points to “Noble”.
I found that I need to change to “Jammy”, but if I make the change in apt.conf.d the installer overwrites it again pointing to “Noble”.
How can I change that?
Thanks in advance
Hello @drmato
Are you using clean freshly installed OS? Could you please show us what repositories are specified in the /etc/apt/sources.list and apt.conf.d file? Additionally, please reproduce the situation and make a screenshot of the issue itself.
Thanks for your response. This will be a long message, but perhaps you can go to the end of it to see a possible cause of the problem
It is a new installation on a vmware virtual machine. We are behind a proxy.
The list of repositories is as follows:
/etc/apt/sources.list is empty, but the content of /etc/apt/souce.list.d is:
mysql.list
nodesource.list
onlyoffice.list
openresty.list
opensearch-2.x.list
opensearch-dashboards-2.x.list
redis.list
ubuntu.sources
cat mysql.list
deb [signed-by=/usr/share/keyrings/mysql-apt-config.gpg] zzzz://repo.mysql.com/apt/ubuntu/noble mysql-apt-config
deb [signed-by=/usr/share/keyrings/mysql-apt-config.gpg] zzzz://repo.mysql.com/apt/ubuntu/noble mysql-8.4-lts
deb [signed-by=/usr/share/keyrings/mysql-apt-config.gpg] zzzz://repo.mysql.com/apt/ubuntu/ noble mysql-tools
deb-src [signed-by=/usr/share/keyrings/mysql-apt-config.gpg] zzzz://repo.mysql.com/apt/ubuntu/noble mysql-8.4-lts
cat nodesource.list
deb [arch=amd64 signed-by=/usr/share/keyrings/nodesource.gpg] zzzz://deb.nodesource.com/node_18.x nodistro main
cat onlyoffice.list
deb [signed-by=/usr/share/keyrings/onlyoffice.gpg] zzzz://download.onlyoffice.com/repo/debian squeeze main
cat openresty.list
deb [signed-by=/usr/share/keyrings/openresty.gpg] zzzz://openresty.org/package/ubuntu jammy main
cat opensearch-2.x.list
deb [signed-by=/usr/share/keyrings/opensearch-keyring] zzzz://artifacts.opensearch.org/releases/bundle/opensearch/2.x/apt stable main
cat opensearch-dashboards-2.x.list
deb [signed-by=/usr/share/keyrings/opensearch-keyring] zzzz://artifacts.opensearch.org/releases/bundle/opensearch-dashboards/2.x/apt stable main
cat redis.list
deb [signed-by=/usr/share/keyrings/redis.gpg] zzzz://packages.redis.io/deb jammy main
cat ubuntu.sources
Types: deb
URIs: zzzz://us.archive.ubuntu.com/ubuntu/
Suites: noble noble-updates noble-backports
Components: main restricted universe multiverse
Signed-By: /usr/share/keyrings/ubuntu-archive-keyring.gpg
Types: deb
URIs: zzzz://security.ubuntu.com/ubuntu/
Suites: noble-security
apt.conf.d directory:
01autoremove
10periodic
20apt-esm-hook.conf
20auto-upgrades
20snapd.conf
50command-not-found
70debconf
99needrestart
01-vendor-ubuntu
15update-stamp
20archive
20packagekit
50appstream
50unattended-upgrades
90curtin-aptproxy
99update-notifier
Or maybe you mean apt.conf?:
Acquire::http::Proxy “http://[my_credentials]@proxy.xxxxxxxx.xxx:8080”;
Acquire::https::Proxy “http://[my_credentials]@proxy.xxxxxxxx.xxx:8080”;
Acquire::ftp::Proxy “http://[my_credentials]@proxy.xxxxxxxx.xxx:8080”;
And the output when running the installer:
root@onlyoffice:~# bash docspace-install.sh package
Hit:1 zzzz://download.onlyoffice.com/repo/debian squeeze InRelease
Hit:2 zzzz://deb.nodesource.com/node_18.x nodistro InRelease
Hit:3 zzzz://repo.mysql.com/apt/ubuntu jammy InRelease
Hit:4 zzzz://artifacts.opensearch.org/releases/bundle/opensearch/2.x/apt stable InRelease
Hit:5 zzzz://artifacts.opensearch.org/releases/bundle/opensearch-dashboards/2.x/apt stable InRelease
Hit:6 zzzz://openresty.org/package/ubuntu jammy InRelease
Hit:7 zzzz://us.archive.ubuntu.com/ubuntu noble InRelease
Hit:8 zzzz://security.ubuntu.com/ubuntu noble-security InRelease
Hit:9 zzzz://us.archive.ubuntu.com/ubuntu noble-updates InRelease
Hit:10 zzzz://us.archive.ubuntu.com/ubuntu noble-backports InRelease
Hit:11 zzzz://packages.redis.io/deb jammy InRelease
Reading package lists… Done
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
100 712 100 712 0 0 1091 0 --:–:-- --:–:-- --:–:-- 1090
BOOTSTRAP
gpg: key 8320CA65CB2DE8E5: “Ascensio System Limited (ONLYOFFICE) <support_onlyoffice.com>” not changed
gpg: Total number processed: 1
gpg: unchanged: 1
100 4404 100 4404 0 0 7384 0 --:–:-- --:–:-- --:–:-- 7376
100 1096 100 1096 0 0 1419 0 --:–:-- --:–:-- --:–:-- 1417
CHECK PORTS
100 7303 100 7303 0 0 12997 0 --:–:-- --:–:-- --:–:-- 13017
INSTALL PREREQUISITES
Hit:2 zzzz://repo.mysql.com/apt/ubuntu jammy InRelease
Hit:3 zzzz://artifacts.opensearch.org/releases/bundle/opensearch/2.x/apt stable InRelease
Hit:4 zzzz://artifacts.opensearch.org/releases/bundle/opensearch-dashboards/2.x/apt stable InRelease
Hit:5 zzzz://deb.nodesource.com/node_18.x nodistro InRelease
Hit:10 zzzz://packages.redis.io/deb jammy InRelease
Hit:11 zzzz://us.archive.ubuntu.com/ubuntu noble-backports InRelease
Generating locales (this might take a while)…
en_US.UTF-8… done
Generation complete.
100 4300 100 4300 0 0 103k 0 --:–:-- --:–:-- --:–:-- 104k
100 4300 100 4300 0 0 107k 0 --:–:-- --:–:-- --:–:-- 110k
2024-11-12 12:22:19 - Installing pre-requisites
Hit:2 zzzz://artifacts.opensearch.org/releases/bundle/opensearch/2.x/apt stable InRelease
Hit:3 zzzz://artifacts.opensearch.org/releases/bundle/opensearch-dashboards/2.x/apt stable InRelease
Hit:4 zzzz://repo.mysql.com/apt/ubuntu jammy InRelease
Building dependency tree… Done
Reading state information… Done
apt-transport-https is already the newest version (2.7.14build2).
ca-certificates is already the newest version (20240203).
curl is already the newest version (8.5.0-2ubuntu10.4).
gnupg is already the newest version (2.4.4-2ubuntu17).
0 upgraded, 0 newly installed, 0 to remove and 2 not upgraded.
Hit:4 zzzz://deb.nodesource.com/node_18.x nodistro InRelease
Hit:5 zzzz://repo.mysql.com/apt/ubuntu jammy InRelease
Hit:6 zzzz://us.archive.ubuntu.com/ubuntu noble InRelease
Hit:7 zzzz://openresty.org/package/ubuntu jammy InRelease
2024-11-12 12:22:24 - Repository configured successfully.
2024-11-12 12:22:24 - To install Node.js, run: apt-get install nodejs -y
2024-11-12 12:22:24 - You can use N|solid Runtime as a node.js alternative
2024-11-12 12:22:24 - To install N|solid Runtime, run: apt-get install nsolid -y
100 50232 100 50232 0 0 343k 0 --:–:-- --:–:-- --:–:-- 345k
100 18072 100 18072 0 0 511k 0 --:–:-- --:–:-- --:–:-- 519k
(Reading database … 124616 files and directories currently installed.)
Preparing to unpack mysql-apt-config_0.8.33-1_all.deb …
Unpacking mysql-apt-config (0.8.33-1) over (0.8.33-1) …
Setting up mysql-apt-config (0.8.33-1) …
gpg: key 5F4349D6BF53AA0C: “Redis (Package Signing) <redis-packages_redis.io>” not changed
gpg: unchanged: 1
gpg: key 97DB7443D5EDEB74: “OpenResty Admin <admin_openresty.com>” not changed
gpg: unchanged: 1
Get:4 zzzz://repo.mysql.com/apt/ubuntu noble InRelease
Err:4 zzzz://repo.mysql.com/apt/ubuntu noble InRelease
Clearsigned file isn’t valid, got ‘NOSPLIT’ (does the network require authentication?)
E: Failed to fetch zzzz://repo.mysql.com/apt/ubuntu/dists/noble/InRelease Clearsigned file isn’t valid, got ‘NOSPLIT’ (does the network require authentication?)
E: The repository ‘zzzz://repo.mysql.com/apt/ubuntu noble InRelease’ is not signed.
N: Updating from such a repository can’t be done securely, and is therefore disabled by default.
N: See apt-secure(8) manpage for repository creation and user configuration details.
There is something strange that I noticed in the InRelease of the mysql repo:
If I edit the mysql.list file to use another distro that is not “noble”, such as “mantic” or “oracular”, and I perform an apt update, it works perfectly, but if I use “noble”, it gives the “no-split” error.
Since the onlyoffice installer itself downloads the “mysql.list” file, I can’t change it to use another distro.
I tried on another server connected without a proxy and it works, so the abnormal behavior occurs only with the noble distro of the mysql repo.
Anyway, thank you very much for your help. I’m going to install another version of Ubuntu and reinstall onlyoffice from there.
Sorry for the errors, I used a translator to try to explain my problem better in English.
Forget it, it was a problem with the Squid configuration. ACLs were created that allow direct access to the necessary repositories and it worked without problems.
Sorry again for the inconvenience.
