Hello @Constantine
my control panel is not working, but this is a problem for another topic.
Here are the versions from docker ps -a command:
On the image above, I just clicked “Generate Report” for simple reproduction of the problem.
And those are the errors I get:
You can find log files below.
web.sql.log:
2024-01-30 08:03:22,195|595|34736|1.9108|Connection.Open||
2024-01-30 08:03:22,195|595|34736|1.0315|Command.ExecuteScalar|SELECT COUNT(*) FROM information_schema.processlist WHERE command = 'Sleep'|
2024-01-30 08:03:22,195|595|34736|0.5239|Connection.BeginTransaction||
2024-01-30 08:03:22,198|595|34750|0.5502|Connection.Open||
2024-01-30 08:03:22,198|595|34750|0.9103|Command.ExecuteScalar|SELECT COUNT(*) FROM information_schema.processlist WHERE command = 'Sleep'|
2024-01-30 08:03:22,198|595|34750|0.6744|Command.ExecuteReader(Default)|select tenant, user_id, path, counter, tag from tenants_quotarow where tenant = @p0 and user_id = @p1 and path = @p2|@p0=1, @p1=1a1ecc5a-e717-44a0-b6a6-5ed64d624ccf, @p2=/files/files_temp
2024-01-30 08:03:22,198|595|34750|0.0038|Connection.Dispose||
2024-01-30 08:03:22,201|595|34736|0.7177|Command.ExecuteNonQuery|update tenants_quotarow set counter = @p0, last_modified = @p1 where tenant = @p2 and path = @p3 and user_id = @p4|@p0=145277, @p1=30. 01. 2024 08:03:22, @p2=1, @p3=/files/files_temp, @p4=1a1ecc5a-e717-44a0-b6a6-5ed64d624ccf
2024-01-30 08:03:22,241|595|34736|40.2744|Transaction.Commit||
2024-01-30 08:03:22,241|595|34736|0.0034|Connection.Dispose||
2024-01-30 08:03:22,252|595|34736|0.6362|Connection.Open||
2024-01-30 08:03:22,253|595|34736|1.1389|Command.ExecuteScalar|SELECT COUNT(*) FROM information_schema.processlist WHERE command = 'Sleep'|
2024-01-30 08:03:22,253|595|34736|0.5763|Command.ExecuteScalar|select value from core_settings where tenant = @p0 and id = @p1|@p0=-1, @p1=DocKey_portal
2024-01-30 08:03:22,253|595|34736|0.0039|Connection.Dispose||
2024-01-30 08:03:22,416|1344|34736|0.6159|Connection.Open||
2024-01-30 08:03:22,418|1344|34736|1.4981|Command.ExecuteScalar|SELECT COUNT(*) FROM information_schema.processlist WHERE command = 'Sleep'|
2024-01-30 08:03:22,424|1344|34736|5.6451|Command.ExecuteReader(Default)|select f.id, f.title, f.folder_id, f.create_on, f.create_by, f.version, f.version_group, f.content_length, f.modified_on, f.modified_by, (select concat(cast(d.folder_type as char), '|', d.create_by, '|', cast(d.id as char)) from files_folder d, files_folder_tree t where d.tenant_id = f.tenant_id and d.id = t.parent_id and t.folder_id = f.folder_id group by level order by level desc limit 1), (select count(*) from files_security s where s.tenant_id = @p0 and s.entry_id = cast(f.id as char) and s.entry_type = @p1 and s.subject_type <> @p2 limit 1), converted_type, f.comment, f.encrypted, f.forcesave, f.thumb, (select 1 from files_link l where l.tenant_id = f.tenant_id and l.linked_id = f.id and l.linked_for = @p3 limit 1), (select group_concat(s.subject) from files_security s where s.tenant_id = @p4 and s.entry_id = cast(f.id as char) and s.entry_type = @p5 and s.subject_type = @p6) from files_file f where f.tenant_id = @p7 and id = @p8 and current_version = @p9|@p0=1, @p1=2, @p2=2, @p3=5cdddf65-3d41-4263-ac2d-92a5ed1f4dc0, @p4=1, @p5=2, @p6=2, @p7=1, @p8=19, @p9=True
2024-01-30 08:03:22,424|1344|34736|0.0621|Connection.Dispose||
2024-01-30 08:03:22,429|1344|34736|0.6016|Connection.Open||
2024-01-30 08:03:22,429|1344|34736|1.1226|Command.ExecuteScalar|SELECT COUNT(*) FROM information_schema.processlist WHERE command = 'Sleep'|
2024-01-30 08:03:22,429|1344|34736|1.8989|Command.ExecuteReader(Default)|select s.tenant_id, cast(t.folder_id as char), s.entry_type, s.subject, s.subject_type, s.owner, s.security, s.options, t.level from files_security s inner join files_folder_tree t on s.entry_id = cast(t.parent_id as char) where s.tenant_id = @p0 and t.folder_id = @p1 and s.entry_type = @p2 union select s.tenant_id, s.entry_id, s.entry_type, s.subject, s.subject_type, s.owner, s.security, s.options, -1 from files_security s where s.tenant_id = @p3 and s.entry_id = @p4 and s.entry_type = @p5|@p0=1, @p1=10, @p2=1, @p3=1, @p4=19, @p5=2
2024-01-30 08:03:22,434|1344|34736|0.0034|Connection.Dispose||
2024-01-30 08:03:22,748|1067|34736|0.6181|Connection.Open||
2024-01-30 08:03:22,750|1067|34736|1.2463|Command.ExecuteScalar|SELECT COUNT(*) FROM information_schema.processlist WHERE command = 'Sleep'|
2024-01-30 08:03:22,750|1067|34736|2.2519|Command.ExecuteReader(Default)|select f.id, f.title, f.folder_id, f.create_on, f.create_by, f.version, f.version_group, f.content_length, f.modified_on, f.modified_by, (select concat(cast(d.folder_type as char), '|', d.create_by, '|', cast(d.id as char)) from files_folder d, files_folder_tree t where d.tenant_id = f.tenant_id and d.id = t.parent_id and t.folder_id = f.folder_id group by level order by level desc limit 1), (select count(*) from files_security s where s.tenant_id = @p0 and s.entry_id = cast(f.id as char) and s.entry_type = @p1 and s.subject_type <> @p2 limit 1), converted_type, f.comment, f.encrypted, f.forcesave, f.thumb, (select 1 from files_link l where l.tenant_id = f.tenant_id and l.linked_id = f.id and l.linked_for = @p3 limit 1), (select group_concat(s.subject) from files_security s where s.tenant_id = @p4 and s.entry_id = cast(f.id as char) and s.entry_type = @p5 and s.subject_type = @p6) from files_file f where f.tenant_id = @p7 and id = @p8 and current_version = @p9|@p0=1, @p1=2, @p2=2, @p3=725bf3de-1930-4c97-9e50-213448b6940c, @p4=1, @p5=2, @p6=2, @p7=1, @p8=697, @p9=True
2024-01-30 08:03:22,753|1067|34736|0.0041|Connection.Dispose||
2024-01-30 08:03:22,753|1067|34736|0.5172|Connection.Open||
2024-01-30 08:03:22,757|1067|34736|0.9183|Command.ExecuteScalar|SELECT COUNT(*) FROM information_schema.processlist WHERE command = 'Sleep'|
2024-01-30 08:03:22,757|1067|34736|1.2929|Command.ExecuteReader(Default)|select s.tenant_id, cast(t.folder_id as char), s.entry_type, s.subject, s.subject_type, s.owner, s.security, s.options, t.level from files_security s inner join files_folder_tree t on s.entry_id = cast(t.parent_id as char) where s.tenant_id = @p0 and t.folder_id = @p1 and s.entry_type = @p2 union select s.tenant_id, s.entry_id, s.entry_type, s.subject, s.subject_type, s.owner, s.security, s.options, -1 from files_security s where s.tenant_id = @p3 and s.entry_id = @p4 and s.entry_type = @p5|@p0=1, @p1=237, @p2=1, @p3=1, @p4=697, @p5=2
2024-01-30 08:03:22,757|1067|34736|0.0033|Connection.Dispose||
web.files.log:
2024-01-30 08:03:22,267 ERROR [595] localhost - ASC.Files - DocService error System.Net.WebException: The remote server returned an error: (500) Internal Server Error.
at System.Net.HttpWebRequest.GetResponseFromData (System.Net.WebResponseStream stream, System.Threading.CancellationToken cancellationToken) [0x00146] in <88f564ea69dd4dc8ba9bf979e48d5996>:0
at System.Net.HttpWebRequest.RunWithTimeoutWorker[T] (System.Threading.Tasks.Task`1[TResult] workerTask, System.Int32 timeout, System.Action abort, System.Func`1[TResult] aborted, System.Threading.CancellationTokenSource cts) [0x000f8] in <88f564ea69dd4dc8ba9bf979e48d5996>:0
at System.Net.HttpWebRequest.GetResponse () [0x00016] in <88f564ea69dd4dc8ba9bf979e48d5996>:0
at ASC.Web.Core.Files.DocumentService.DocbuilderRequest (System.String docbuilderUrl, System.String requestKey, System.String scriptUrl, System.Boolean isAsync, System.String signatureSecret, System.Collections.Generic.Dictionary`2[System.String,System.String]& urls) [0x00165] in <74e1fc20d6d544179ea145c88676f874>:0
at ASC.Web.Files.Services.DocumentService.DocumentServiceConnector.DocbuilderRequest (System.String requestKey, System.String inputScript, System.Boolean isAsync, System.Collections.Generic.Dictionary`2[System.String,System.String]& urls) [0x00085] in <db3cf20951e74c1cb613da003cfb9a75>:0
2024-01-30 08:03:22,270 ERROR [595] localhost - ASC.Files - DocbuilderReportsUtility error System.Exception: Zgodila se je napaka v storitvi dokumenta (The remote server returned an error: (500) Internal Server Error.) ---> System.Net.WebException: The remote server returned an error: (500) Internal Server Error.
--- End of inner exception stack trace ---
at ASC.Web.Files.Services.DocumentService.DocumentServiceConnector.DocbuilderRequest (System.String requestKey, System.String inputScript, System.Boolean isAsync, System.Collections.Generic.Dictionary`2[System.String,System.String]& urls) [0x0009a] in <db3cf20951e74c1cb613da003cfb9a75>:0
at ASC.Web.Files.Services.DocumentService.ReportState.GenerateReport (ASC.Common.Threading.DistributedTask task, System.Threading.CancellationToken cancellationToken) [0x00074] in <db3cf20951e74c1cb613da003cfb9a75>:0
nginx.access.log:
192.168.141.60 - - [30/Jan/2024:08:02:22 +0000] "POST /Products/Files/Services/WCFService/service.svc/checkediting?_=1706601742578 HTTP/1.1" 200 29 "http://10.0.203.10/Products/Files/?desktop=true&" "Mozilla/5.0 (Windows NT 6.2; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/87 AscDesktopEditor/7.1.0 Safari/537.36"
127.0.0.1 - - [30/Jan/2024:08:02:27 +0000] "GET /api/2.0/capabilities.json HTTP/1.1" 200 133 "-" "Ruby"
127.0.0.1 - - [30/Jan/2024:08:02:32 +0000] "GET /api/2.0/capabilities.json HTTP/1.1" 200 133 "-" "Ruby"
192.168.143.41 - - [30/Jan/2024:08:02:34 +0000] "POST /Products/Files/Services/WCFService/service.svc/checkediting?_=1706601754333 HTTP/1.1" 200 29 "http://10.0.203.10/Products/Files/" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/121.0.0.0 Safari/537.36"
127.0.0.1 - - [30/Jan/2024:08:02:37 +0000] "GET /api/2.0/capabilities.json HTTP/1.1" 200 133 "-" "Ruby"
192.168.141.3 - - [30/Jan/2024:08:02:40 +0000] "POST /Products/Files/Services/WCFService/service.svc/checkediting?_=1706601760402 HTTP/1.1" 200 99 "http://10.0.203.10/Products/Files/" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/121.0.0.0 Safari/537.36 Edg/121.0.0.0"
127.0.0.1 - - [30/Jan/2024:08:02:42 +0000] "GET /api/2.0/capabilities.json HTTP/1.1" 200 133 "-" "Ruby"
192.168.141.60 - - [30/Jan/2024:08:02:42 +0000] "POST /Products/Files/Services/WCFService/service.svc/checkediting?_=1706601762624 HTTP/1.1" 200 29 "http://10.0.203.10/Products/Files/?desktop=true&" "Mozilla/5.0 (Windows NT 6.2; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/87 AscDesktopEditor/7.1.0 Safari/537.36"
127.0.0.1 - - [30/Jan/2024:08:02:47 +0000] "GET /api/2.0/capabilities.json HTTP/1.1" 200 133 "-" "Ruby"
127.0.0.1 - - [30/Jan/2024:08:02:52 +0000] "GET /api/2.0/capabilities.json HTTP/1.1" 200 133 "-" "Ruby"
192.168.143.41 - - [30/Jan/2024:08:02:55 +0000] "POST /Products/Files/Services/WCFService/service.svc/checkediting?_=1706601775332 HTTP/1.1" 200 29 "http://10.0.203.10/Products/Files/" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/121.0.0.0 Safari/537.36"
127.0.0.1 - - [30/Jan/2024:08:02:57 +0000] "GET /api/2.0/capabilities.json HTTP/1.1" 200 133 "-" "Ruby"
192.168.141.3 - - [30/Jan/2024:08:03:01 +0000] "POST /Products/Files/Services/WCFService/service.svc/checkediting?_=1706601781401 HTTP/1.1" 200 99 "http://10.0.203.10/Products/Files/" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/121.0.0.0 Safari/537.36 Edg/121.0.0.0"
127.0.0.1 - - [30/Jan/2024:08:03:02 +0000] "GET /api/2.0/capabilities.json HTTP/1.1" 200 133 "-" "Ruby"
192.168.141.60 - - [30/Jan/2024:08:03:02 +0000] "POST /Products/Files/Services/WCFService/service.svc/checkediting?_=1706601782676 HTTP/1.1" 200 29 "http://10.0.203.10/Products/Files/?desktop=true&" "Mozilla/5.0 (Windows NT 6.2; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/87 AscDesktopEditor/7.1.0 Safari/537.36"
127.0.0.1 - - [30/Jan/2024:08:03:07 +0000] "GET /api/2.0/capabilities.json HTTP/1.1" 200 133 "-" "Ruby"
127.0.0.1 - - [30/Jan/2024:08:03:12 +0000] "GET /api/2.0/capabilities.json HTTP/1.1" 200 133 "-" "Ruby"
192.168.141.28 - - [30/Jan/2024:08:03:15 +0000] "GET /api/2.0/project/report/terminate.json?__=949368 HTTP/1.1" 200 55 "http://10.0.203.10/Products/Projects/Reports.aspx?reportType=0" "Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/120.0.0.0 Safari/537.36"
192.168.143.41 - - [30/Jan/2024:08:03:16 +0000] "POST /Products/Files/Services/WCFService/service.svc/checkediting?_=1706601796329 HTTP/1.1" 200 29 "http://10.0.203.10/Products/Files/" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/121.0.0.0 Safari/537.36"
127.0.0.1 - - [30/Jan/2024:08:03:17 +0000] "GET /api/2.0/capabilities.json HTTP/1.1" 200 133 "-" "Ruby"
192.168.141.28 - - [30/Jan/2024:08:03:22 +0000] "POST /api/2.0/project/report/create.json?__=469821 HTTP/1.1" 201 197 "http://10.0.203.10/Products/Projects/Reports.aspx?reportType=0" "Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/120.0.0.0 Safari/537.36"
127.0.0.1 - - [30/Jan/2024:08:03:22 +0000] "GET /api/2.0/capabilities.json HTTP/1.1" 200 133 "-" "Ruby"
172.18.0.1 - - [30/Jan/2024:08:03:22 +0000] "POST /docbuilder HTTP/1.1" 500 4887 "-" "-"
192.168.141.3 - - [30/Jan/2024:08:03:22 +0000] "POST /Products/Files/Services/WCFService/service.svc/checkediting?_=1706601802401 HTTP/1.1" 200 99 "http://10.0.203.10/Products/Files/" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/121.0.0.0 Safari/537.36 Edg/121.0.0.0"
192.168.141.60 - - [30/Jan/2024:08:03:22 +0000] "POST /Products/Files/Services/WCFService/service.svc/checkediting?_=1706601802725 HTTP/1.1" 200 29 "http://10.0.203.10/Products/Files/?desktop=true&" "Mozilla/5.0 (Windows NT 6.2; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/87 AscDesktopEditor/7.1.0 Safari/537.36"
192.168.141.28 - - [30/Jan/2024:08:03:23 +0000] "GET /api/2.0/project/report/status.json?__=408435 HTTP/1.1" 200 275 "http://10.0.203.10/Products/Projects/Reports.aspx?reportType=0" "Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/120.0.0.0 Safari/537.36"
127.0.0.1 - - [30/Jan/2024:08:03:27 +0000] "GET /api/2.0/capabilities.json HTTP/1.1" 200 133 "-" "Ruby"
127.0.0.1 - - [30/Jan/2024:08:03:32 +0000] "GET /api/2.0/capabilities.json HTTP/1.1" 200 133 "-" "Ruby"
127.0.0.1 - - [30/Jan/2024:08:03:37 +0000] "GET /api/2.0/capabilities.json HTTP/1.1" 200 133 "-" "Ruby"
192.168.143.41 - - [30/Jan/2024:08:03:37 +0000] "POST /Products/Files/Services/WCFService/service.svc/checkediting?_=1706601817323 HTTP/1.1" 200 29 "http://10.0.203.10/Products/Files/" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/121.0.0.0 Safari/537.36"
If you need any additional information, please tell me.
Best regards,
Joze
