Problem connecting Nextcloud with onlyoffice via connector
Okay, let me know when you are ready to continue.
why if i chek healthchek in browser
cannot get /healthchek
Hello @wawan
In your reply word has a typo, correct spelling is healthcheck.
Hi,
I have the same problem with nextcloud and onlyoffice in two different servers:
office.claimcenter.com running onlyoffice document server 8.3.2
cloud.rafelamer.com running netcloud 30.0.8
Both servers runs rocky linux 9.
Here’s my config/config.php in the nexcloud server
<?php
$CONFIG = array (
  'maintenance_window_start' => 1,
  'instanceid' => 'xxxxxxxxxxxx',
  'passwordsalt' => 'xxxxxxxxxxxxxxxxxxxxxxxxxxxxxx',
  'secret' => 'xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx',
  'trusted_domains' =>
  array (
    0 => 'cloud.rafelamer.com',
    1 => 'nuvol.agn.dance',
    2 => 'office.claimcenter.com',
  'datadirectory' => '/home/nextcloud/',
  'dbtype' => 'pgsql',
  'version' => '30.0.8.1',
  'overwrite.cli.url' => 'https://cloud.rafelamer.com',
  'dbname' => 'nextcloud',
  'dbhost' => 'localhost',
  'dbport' => '',
  'dbtableprefix' => 'oc_',
  'dbuser' => 'ogo',
  'dbpassword' => '',
  'installed' => true,
  'ldapIgnoreNamingRules' => false,
  'ldapProviderFactory' => 'OCA\\User_LDAP\\LDAPProviderFactory',
  'maintenance' => false,
  'memcache.distributed' => '\\OC\\Memcache\\Redis',
  'memcache.local' => '\\OC\\Memcache\\Redis',
  'redis' =>
  array (
    'host' => '127.0.0.1',
    'port' => 6379,
  'memcache.locking' => '\\OC\\Memcache\\Redis',
  'theme' => '',
  'updater.release.channel' => 'stable',
  'mail_smtpmode' => 'smtp',
  'mail_smtpauthtype' => 'PLAIN',
  'mail_sendmailmode' => 'smtp',
  'mail_smtpsecure' => 'tls',
  'mail_smtpauth' => 1,
  'default_phone_region' => 'ES',
  'encryption.legacy_format_support' => false,
  'encryption.key_storage_migrated' => false,
  'mail_domain' => 'rafelamer.com',
  'mail_from_address' => 'admin',
  'mail_smtphost' => 'mail.rafelamer.com',
  'mail_smtpport' => '25',
  'mail_smtpname' => 'admin',
  'mail_smtppassword' => 'xxxxxxxxxxxxxxxxxxxxx',
  'app_install_overwrite' =>
  array (
    0 => 'bbb',
  'loglevel' => 3,
  'auth.bruteforce.protection.enabled' => false,
  'onlyoffice' =>
  array (
    'verify_peer_off' => true,
    'jwt_secret' => 'xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx',
    'jwt_header' => 'AuthorizationJWT'
And that’s my /etc/onlyoffice/documentserver/local.json in the onlyoffice server
  "services": {
    "CoAuthoring": {
      "sql": {
        "dbHost": "localhost",
        "dbName": "onlyoffice",
        "dbUser": "onlyoffice",
        "dbPass": "xxxxxxxxxxxxxxxxxxxxxxxxxxxxxx",
        "type": "postgres",
        "dbPort": "5432"
      "token": {
        "enable": {
          "request": {
            "inbox": true,
            "outbox": true
          "browser": true
        "inbox": {
            "header": "Authorization"
        "outbox": {
      "secret": {
        "inbox": {
          "string": "xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx"
        "outbox": {
        "session": {
  "queue": {
    "type": "rabbitmq"
  "rabbitmq": {
    "url": "amqp://onlyoffice:xxxxxxxxxxxxxxxxxxxxxxxxxx@localhost"
When I click the Save button in the onlyoffice configuration page in Nextcloud, I get the error
Error occurred in the document service: Error while downloading the document file to be converted. (version 8.3.2.19)
I think that the problem is that, when I click the Save button, the function getConvertedUri in apps/onlyoffice/lib/DocumentService.php in the Nexcloud server sends a request to https://office.claimcenter.com. When the onlyoffice server receives this request, it send a request back to the Nexcloud server
ttps://cloud.rafelamer.com/index.php/apps/onlyoffice/empty?doc=eyJ0eXAiOiJKV1QiLCJhbGciOiJIUzI1NiJ9.eyJhY3Rpb24iOiJlbXB0eSJ9.vu9Aj0Y27pHZgCYqj3mW7LqdcIgz7-5UK5aSjtdBfUk
but it receives 403 Forbidden from the Nexcloud server.
Does anybody knows how can I solve this problem?
Best regards,
Rafel Amer
Hello @rafel.amer
You are using different JWT headers in Document Server and Nextcloud configs. Change them so that in both configs the same value is used and then try again.
