ONLYOFFICE Mobile: Documents
Do you want to: Suggest a feature
Allow existing numpad keyboards to be used for continuous number entry instead of disappearing after a single number
An example screenshot video follows
Device: iPhone 13
OS version: 18
App version: 8.1
Mode: On Device
Can’t insert a mov iPhone file recording, the forum doesn’t allow it
The correct behavior: not only should the keyboard remain open (this happens in some other excel apps), but it should retain the numeric input mode (this is another common issue for apps without own numpads, though it should be possible with 3rd party apps since, for example, PlanMaker has a special extra button that switches stock Apple keyboard into a numeric mode, so it’s possible to signal the keyboard to switch back to that mode even if it loses it after a single cell entry)
Hello @esv
You can now upload files in .mov format.
We look forward to viewing the recording you’ve attached.
Thank you for the suggestion!
Thank you, @esv
We will definitely look into this issue and notify you as soon as we have any updates.
@esv
We have reproduced the behavior you described and have submitted a proposal for implementation. Once the proposal is implemented, I will notify you and update the information in this thread.
Thank you for bringing this to our attention!
