Presenter: wrong monitor settings
hallo, I have a problem with Presenter: the presentation stays on PC primary monitor 1, and the presenter view with my notes opens on extended 2. obviously it must work the other way around, but I can’t find how to fix it!
thank you for your help…
Hello @paolo
Unfortunately, currently you cannot configure which monitor will display presentation in Presenter mode and which in Preview Mode.
We have the enhancement suggestion number 39337 registered in our internal tracker to add such functionality in future releases. However, we do not have any estimated time frames of the release available yet.
Sorry for the inconvenience caused.
thank you, I hope you can fix this problem as soon as possible, otherwise unfortunately it’s impossible to use your nice software in the best way!
Hello again @paolo
Currently, we are actively working on this issue and we have come up to simple workaround solution that you can use right now: drag your presentation editor window to the second monitor and launch Presenter mode from it. That way you will have the slideshow going on the second monitor and Presenter mode on the main one.
WOW, thank you! it’s true, with this little trick it works… thanks again
Hello again @paolo
We have released version 7.4 of Document Server which includes fix of the issue mentioned in this thread.
Please update your current instance and provide us a feedback.
wow now it works! thank you
