Presentation Editor rotation
I noticed since 8.0.0, mobile app for presentation file. If at portrait mode, the id_panel_thumbnails goes to the bottom and with landscape mode, the id_panel_thumbnails goes to the left. This is great !
But my built community edition always put the id_panel_thumbnailsto the left.
Is there an interface config for that ?
I was using 7.5.1 document-server with example (type=mobile). Is documents-app-android has it’s own design that leverage Fragment for the rotation so that the id_panel_thumbnails smoothly switch between bottm and left ?
Hello @shooding
We are checking the described scenario. I will come back as soon as possible.
Update:
Unfortunately, there’s no way to achieve the same behavior on mobile editor. The mobile app has its own design and logic of work. However, we are working on it already. I will update this thread once we release the same function for mobile editor as for mobile app.
Sorry for inconvenience.
