Presentation bug - changing tabulation does not work in a text area
In a text area, I want to change the tabulation of a part of the text:
editors_20230618-11h37min50s
It is not working as you can see.
File:
But: when I copy/paste the slide in a new presentation, the problem is gone…
Thank you for the file and a GIF! :wink:
We are checking the situation.
Was file bug tabulations.pptx created entirely in ONLYOFFICE or copied from another editor?
Hi
The slide was copied from another pptx file.
I can’t say if the original slide was made in OO or in MSO (as, to create a new file, I’m duplicating a previous one, and before february I was using MSO).
HI @arcqus
:ok_hand:
We have reproduced the issue and added bug to our internal tracking system.
Thank you for contributing to our product. We will try to fix bug in the next versions.
