For feature suggestions, describe the result you would like to achieve in detail:
Document Server version:
Installation method:
OS: win11
Browser version:
try to use plugins , from github. they installed , but not show up in plugins tab
Which Plugin? Can you provide us the link for this plugin? How did you install via GitHub?
i try two plugins: helloworld and num2word
installed through plugin manager and manually through plugin folder
I see them in the manager, but But they didn’t show up in plugins tab and I can’t delete them via plugin manager
Hello @Sw51
Have you tried to clean browser cache\cookies or used different browser? If it doesn’t help please let us know the exact product and product version that you are using and record a video file with your test and description.
