Plugins.autostart stopped working in 8.2.0.143
Do you want to: Report a bug
I’m trying to to autostart plugin with DocumentEditor React component.
          editorConfig: {
            plugins: {
              autostart: ["asc.{X9E7B03B-3314-4F69-A190-BCE1C5FA2128}"],
              pluginsData: ["http://192.168.50.121:5173/config.json"],
Plugin icon gets loaded to left side, but when the icon is clicked, it will generate Javascript error
app.js:8 Uncaught TypeError: Cannot read properties of undefined (reading 'menu')
    at n.showPluginPanel (app.js:8:468531)
    at plugins:showpanel (app.js:8:1935483)
    at app.js:8:136527
    at Function.Ce (app.js:8:96670)
    at o.<anonymous> (app.js:8:136505)
    at app.js:8:93536
    at Function.Ce (app.js:8:96726)
    at o.fireEvent (app.js:8:136424)
    at n.fireEvent (app.js:8:135923)
    at n.onBtnCategoryClick (app.js:8:1616934)
Plugin autostart was working in 8.1.3.4 but after update to 8.2.0.143, it stopped working.
When autostart is removed from editorConfig, plugin works fine in editor when it is manually opened.
Hello @tuomasglad
As far as I understand, you have already contacted colleagues of mine via Zendesk. Please do not post the same request in different communication channels and wait for the reply in the Zendesk.
me too.autostart not working
Hello @langziyang
I believe we need to check out the situation from scratch. If it’s possible, please provide us with your plugin, we will check out the autostart feature.
