Could you make it so charts adjust range with pivot table?
When I add chart to a pivot table the range is always the same
and it doesn’t follow the height of the pivot table like with
normal table.
Hello @stanislav
Please check your PM. Recently I sent you a file example where chart works correctly with slicers and pivot table.
If I misunderstood your request, please clarify it.
