我发发现一些pdf文件,内容展示不全,尤其是左右两侧有内容隐藏,下图为现象
您好,
请您告诉我们您使用的编辑器是什么版本?
请发给我们您的PDF文件 所以我们可以检查一下.
1.My version is 7.1.1
2.How can I send you the document? I can’t select pdf, only pictures
You can use this document to test:https://github.com/ONLYOFFICE/DocumentServer/files/10311773/test-source.pdf
We are checking the situation and we will notify you when we have something to share.
Also, version 7.1.1 is already outdated, if it’s possible please update your installation to the latest version.
This problem also exists in version 7.2
Hello, is there any result for this question? I’m waiting for a reply
and this pdf file is generated by pd4ml java
There are no results at the moment, we will inform you about any news.
Hello @yuhui
We have checked mentioned situation and we added a bug to internal tracksystem (internal number - 60441). We have started working on it.
Thank you for valuable data!
