PDF with hyperlinks to a section inside the document doesn’t work properly. PDF application redirects to the end of the document instead of to the section location.
Tested on Ubuntu 20.04 and Linux Mint 21.3.
ONLYOFFICE 8.1.1.27
ONLYOFFICE 8.1.1.27
After some testing, it appears that hyperlinks always redirect to double the intended page number. For example, if the hyperlink should go to page 12, OnlyOffice redirects to page 24. This behavior has been tested in different documents with the same results.
@rubenpadial
Could you please provide the document where the issue is reproducible, along with a short video showing the problem?
Additionally, could you confirm on which product installation this issue happens: snap or flatpak?
This will help us in diagnosing the issue more accurately.
Same behaviour in Ubuntu installed with snap and Linux Mint installed with flatpak
It happens with every document.
Could you please provide the original document so that we can quickly reproduce the issue using your file?
Hey @rubenpadial
ONLYOFFICE 8.1.1.27
Thank you for the attached file!
ONLYOFFICE 8.2 has been recently released, and it resolves issues with hyperlink navigation in PDFs.
Please try updating to version 8.2.0.143, and the links should work correctly.
