I am a student and I have a strong interest in OnlyOffice. I attempted to compile OnlyOffice on Windows, and after the compilation was completed, I opened a PDF file. However, when I clicked the “Edit PDF” button, the “Edit Text” button did not appear.
After completing the compilation, I discovered that I was unable to edit the text when I opened the PDF file. I identified an issue: If I replace the officially compiled sdkjs, I can edit the PDF text without any problems. I suspect this is due to the missing sdkjs-ooxml library, but I am having difficulty locating it. Could you please help me find it?
Could you please elaborate on this? What exactly means "replace? Please share the sequence of actions that you are describing step by step. for better understanding.
I’m sorry. What I mean is that after I installed the officially compiled DesktopEditors_x64.exe installation package, I found the “editor\ssdkjs” directory in the installation directory, copied it to the directory I compiled myself, and then I could edit PDF text normally.
I suspect this is due to the missing sdkjs-ooxml library. (I can find the sdkjs-forms repository on GitHub but not the sdkjs-ooxml repository.) but I am having difficulty locating it. Could you please help me find it?
I was just informed that the possibility to build Desktop Editors with this function will be available in version 9.0. Of course as soon as buildtools gets updated too.
@Constantine
Thanks, I’ve compiled successfully, and the edit text button is displayed. However, there are several problems with this feature, and after I clicked the edit text button, the layout became disordered. Thank you anyway.
