PDF Editor custom annotations
Hi,
is there an easy way to add fixed custom annotations (e.g. specific images / stamps) to the PDF editor? E.g., via a new custom permanent menu items?
Thanks!
Hello @ipdoc1
Please describe the desired scenario as detailed as possible. You can make screenshots or video file.
If you are looking for the custom menu items, probably this method might help: AddContextMenuItem - ONLYOFFICE Api Documentation
We want to add a new button in the menu. When clicking on that button, we want to place a custom pdf annotation (image) on the document.
The integration of the button in the menu is probably not the problem, but the custom annotation on the document is.
Just to clarify the entire scenario. Do I understand it right that the entire scenario is as follows: click on the new context button triggers insert image to the pdf file process similar to how you would do it via via Insert-Image from file?
Yes, more or less. I also want to set up the image dynamically via JS, convert it to an SVG and then to an PNG. That image should be placed as annotation, then onto the PDF.
So my question is, where can I start to implement this custom function?
Hello @ipdoc1
We need some time to check out the situation. I will contact you as soon as possible.
Hi @Alexandre, do you may have any news regarding this topic?
Hello @ipdoc1
We are working on it. Once any news come up, you will be notified.
Dear @ipdoc1
Sorry for the late reply. We have added your suggestion to internal tracksystem. We have started working on it.
We will update this thread once we have something to share.
Any news? @Alexandre
Hello @ipdoc1
We are still working on the reported suggestion, I will update this thread once we have something to share.
