Hi,
Do you want to: Report a bug / Ask a how-to question
Bug 1: -
- Generate an Invoice with the sales module of Odoo.
- Open PDF with Onlyoffice docs.
- Click on the Edit PDF button.
- Click on the Edit text.
- Get the error: “An error occurred during the work with the document. Use the ‘Download as’ option to save the file backup copy to a drive.”
Error stack:
onlyoffice-documentserver | [2024-10-10T14:50:03.850] [ERROR] [localhost] [46104e9787d7b824af00ae9d110802fade34474b2d1] [21] nodeJS - clientLog: changesError: Error: Uncaught TypeError: Cannot read properties of null (reading 're')
onlyoffice-documentserver | Script: http://172.19.0.7/8.1.3-4/sdkjs/word/sdk-all.js
onlyoffice-documentserver | Line: 2879:65
onlyoffice-documentserver | userAgent: Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/128.0.0.0 Safari/537.36
onlyoffice-documentserver | platform: Linux x86_64
onlyoffice-documentserver | isLoadFullApi: true
onlyoffice-documentserver | isDocumentLoadComplete: true
onlyoffice-documentserver | DocumentInfo:
onlyoffice-documentserver | Selection: false
onlyoffice-documentserver | performance.memory: {"totalJSHeapSize":86469309,"usedJSHeapSize":82231401,"jsHeapSizeLimit":2172649472}
onlyoffice-documentserver | StackTrace: TypeError: Cannot read properties of null (reading 're')
onlyoffice-documentserver | at e.px (http://172.19.0.7/8.1.3-4/sdkjs/word/sdk-all.js:2879:65)
onlyoffice-documentserver | at a.<anonymous> (http://172.19.0.7/8.1.3-4/sdkjs/word/sdk-all.js:6720:247)
onlyoffice-documentserver | at Object.U [as ug] (http://172.19.0.7/8.1.3-4/sdkjs/word/sdk-all.js:1661:175)
onlyoffice-documentserver | at y.Wg (http://172.19.0.7/8.1.3-4/sdkjs/word/sdk-all.js:6720:36)
onlyoffice-documentserver | at a.tc (http://172.19.0.7/8.1.3-4/sdkjs/word/sdk-all.js:11993:311)
onlyoffice-documentserver | at a.oh (http://172.19.0.7/8.1.3-4/sdkjs/word/sdk-all.js:11984:452)
onlyoffice-documentserver | at http://172.19.0.7/8.1.3-4/sdkjs/word/sdk-all.js:11720:403
onlyoffice-documentserver | at Array.forEach (<anonymous>)
onlyoffice-documentserver | at e.mtd (http://172.19.0.7/8.1.3-4/sdkjs/word/sdk-all.js:11720:381)
onlyoffice-documentserver | at e.DDa (http://172.19.0.7/8.1.3-4/sdkjs/word/sdk-all.js:11698:402)
Got the same error using the Test Example provided by the document server, uploading the same PDF file.
Stack Error from the Test Example:
[2024-10-10T14:19:22.723] [ERROR] [localhost] [172.17.0.1INV_2024_testt.pdf1728568246067] [uid-15] nodeJS - clientLog: changesError: Error: TypeError: this.ja is null
Script: http://localhost/8.1.3-4/sdkjs/word/sdk-all.js
Line: 2879:57
userAgent: Mozilla/5.0 (X11; Linux x86_64; rv:130.0) Gecko/20100101 Firefox/130.0
isLoadFullApi: true
DocumentInfo:
Selection: false
StackTrace: e.prototype.px@http://localhost/8.1.3-4/sdkjs/word/sdk-all.js:2879:57
y.Wg/<@http://localhost/8.1.3-4/sdkjs/word/sdk-all.js:6720:247
U@http://localhost/8.1.3-4/sdkjs/word/sdk-all.js:1661:175
y.Wg@http://localhost/8.1.3-4/sdkjs/word/sdk-all.js:6720:36
a.prototype.tc@http://localhost/8.1.3-4/sdkjs/word/sdk-all.js:11993:311
a.prototype.oh@http://localhost/8.1.3-4/sdkjs/word/sdk-all.js:11984:452
e.prototype.mtd/<@http://localhost/8.1.3-4/sdkjs/word/sdk-all.js:11720:403
e.prototype.mtd@http://localhost/8.1.3-4/sdkjs/word/sdk-all.js:11720:381
e/this.DDa@http://localhost/8.1.3-4/sdkjs/word/sdk-all.js:11698:402
e/this.A6c@http://localhost/8.1.3-4/sdkjs/word/sdk-all.js:11650:50
Also tried generating a PDF file with onlyoffice and got the bug bellow.
Bug 2
Generate a PDF document using a DOCX document using Onlyoffice Docs. (The DOCX was not uploaded to the Test Example. I’ve created it within the Text Example).
Open the newly PDF created with OnlyOffice.
Click on the “Edit PDF” button.
Click on “Edit text” button.
The document turn all blank.
Stack Error: None.
Document Server version: 8.1.3-4
Type of installation of the Document Server (docker, deb/rpm, exe, please point us to the installation guide that you used as well): Docker (Installation Guide: Running ONLYOFFICE Docs using Docker Compose - ONLYOFFICE)
Connector version: Downloaded from ONLYOFFICE | Odoo Apps Store
DMS (platform) version: Odoo 17
Browser version: Firefox and Google Chrome
Additional information:
I utilized the Docker Compose setup from the guide and also tested with a fresh Docker image from Docker Hub:
docker pull onlyoffice/documentserver:latest
Run command:
docker run -i -t -p 80:80 onlyoffice/documentserver:latest --network odoo-onlyoffice-network
I’m running both docker containers (from Odoo and OnlyOffice in a local environment.
I’ve also tested this in a fresh install of OnlyOffice and Odoo (The only modules installed are the Sales Module and the OnlyOffice Connector)
