I have a table in Spreadsheet (with conditional formatting where some values get red and bold above a certain number) and want to copy some values in a table in Document, it only copies the text, not the colour of the text or the bold format, so I have to manually change these every time…
Is there something I can do for this?
Hello @testgcd,
What is the version of the Editor?
Could you please provide the screen recording of the issue reproduction?
I haven’t been able to reproduce the issue on 8.3.2. Here is what I did:
- Created a column populated with numbers from 1 to 10
- Applied conditional formatting (new rule) to this range - colored numbers greater than 5 with blue and made them bold
- Copied the whole range
- Pasted it in the next column to the right
Result: the style was preserved when pasting (I used Ctrl+V for pasting, there are also other pasting options available from the Ctrl context menu that becomes available after the pasting)
