P.1 - Registred bugs: text editor (9.0.0.172 (x64 exe))
Hi there, wanted to drop by and make a feedback on bags and some suggestions for the current version of the editors, precisely for the text editor (9.0.0.172 (x64 exe)).
I’ll try to thoroughly text-describe them, but please let me know if you will need a video representation and on which points. All of them are connected with the tables in the text editor.
  1. Select a row in a table → column break : the result - text in the left cell or in the top left, if you select multiple rows gets deleted
  2. Select text in a cell or multiple cells → Delete : text gets deleted, BUT the font changes to Arial_11 from whatever font and size was in the cell before
  3. Select text in a single cell → Ctrl+B : font changes to bold as expected ; select 2+cells in one row or multiple rows → Ctrl+B : font also changes to bold BUT you can’t invert the change by pressing Ctrl+B again - it does not change the thickness of the font back to the normal
  4. I don’t know whether it’s a bug or intended, but after table/column break, the font on the new line below the table changes back to Arial_11 instead of what it was like in the table or in the text ahead.
I’ll provide video representation on the bugs if you’d need a better illustration, just get back to me with which points exactly need to be presented in the vid. I use a ultra-shady online screen tracker, so if there’s no need and I can describe things via text, I’d rather go with this first
Hello @ohmin
I’ve tried to reproduce p.2-3, however without luck. As for p.1,4 more detailed description is needed. If it’s possible, please record a video file with your test and provide a test file.
One more thing. These issues seem strange, so I would recommend total app reinstallation with cache data clearing before new tests:
111111111
