I want to generate a table’s name as an output within a table-sheet.
In Excel it works like: =TEIL(FORMELTEXT(A1);2;FINDEN(“[”;FORMELTEXT(A1))-2)
So if the sheet is called “sheet1” the output within this cell will be “sheet1”
Is there a formula for oo to generate to generate the same output?
Hi @hoc
Can you try this formula:
=MID(CELL("filename",A1),FIND("]",CELL("filename",A1))+1,255)
hoc
11 March 2024 13:53
4
Hi Nikolas, using your formula creates an error message “The formula contains an error. Wrong arguments count used”.
@hoc
What version of the editor do you have and what formula language is being used?
hoc
12 March 2024 11:09
7
Hallo Nikolas, thank you, Problem solved. I changed language to english, used your formula and it worked. Changing back the language showed me the right german solution: =TEIL(ZELLE(“filename”;A1);FINDEN(“]”;ZELLE(“filename”;A1))+1;255)
Hey @hoc
I need to clarify one point:
When updating the table (F9), does the formula work correctly?
Hey @hoc
We have reproduced the issue and created a bug report regarding the behavior of this formula in languages other than English.
Hey @hoc
Nikolas:
I wanted to inform you that ONLYOFFICE Docs v8.1.0 has been released , and the bug has been fixed .
For more details and the full list of new features in version 8.1.0, please refer to the changelog: Version 8.1.0 Changelog .
