Hello
In the wordprocessor, when en element (ie a picture, a text box) ends up out of the page (to be it was an unexpected result form a copy/past, but let’s not dwell on that for now), it is invisible and then hard to get, unless you know where it is:
![editors_20240316-18h33min48s](https://forum.onlyoffice.com/uploads/default/original/2X/7/73d225be59190d054d4bba6f22353b6e2e6dd405.gif)
IMO it should be visible in a way or another.
Thanks.
hide object.docx (37.0 KB)
Hello
In addition, it should be also the case with tables:
When copy-pasting from another doc (for instance from a landscape doc to a portray one), it’s a pain not to be able to easily modify out-of page columns.
Hello @arcqus
Have you ever seen such possibility in any other editor? Honestly, among those I’ve used processors are usually completely hiding such elements out of canvas.
May I ask you to create a separate thread for this issue as it does not seem to be related to the content specifically out of range of canvas?
Hello @Constantine
I don’t remember MSO and just gave it a look in LO, and … you’re right ![:slight_smile: :slight_smile:](https://forum.onlyoffice.com/images/emoji/twitter/slight_smile.png?v=12)
However, in LO, in the “view” options, I see that there is a “web” mode that allows you to see those elements.
Moreover, LO forbids you to move an element out of the page,
![firefox_20240323-06h56min40s](https://forum.onlyoffice.com/uploads/default/original/2X/8/854850dab0c0cfb4d97adbd66a5ea13897ca9805.gif)
while in OO you can:
![firefox_20240323-06h58min12s](https://forum.onlyoffice.com/uploads/default/original/2X/9/9b3733f7b5c3ed1022799ae8d15822e307306c9f.gif)
Maybe this is the improvement that should be implemented ?
And/or the “web view” ?
I will.
Thanks
Thank you for the feedback. We are checking the situation. I will let you know once I get any news.
I have found out that suggestion to implement feature to view document in web-page mode has been already registered. We believe it is more suitable solution for such issue so your request was collected and added to the suggestion. Thank you for contribution.
