Option to view multiple files side by side
It would be better if we could tab tiles in onlyoffice like in Vivaldi browser or to use 4-window panels with tab support like in Q-dir (Q-dir is alternative to Windows Explorer). Both are good, but we can only have one, I would like to see the q-dir option applied in onlyoffice. The developers can check the the first option in vivaldi browser that I mentioned,
and for the Q-dir option, I have named the screenshots from window pane 1 to window pane 12. If 3 and 4 tiles are too much for onlyoffice then at least make 2 (tile vertically and tile horizontally), you can check screenshot named window pane 8 and window pane 9 for tile vertically and tile horizontally.
Hello @nicesto
I think it would be quite unformfortable to work on more than two files at the same time.
By the way, you can set up Desktop Editors so that every file will be opened in a separate window (Settings menu on the main screen > Open file > In its own window) or by dragging down the document tab to make it windowed and then dragging it to the left/right side of the screen to display the windows on the half of the screen.
Also it works with quarters of the screen - drag the window to any corner and the editors window will be displayed in the quarter of the corner.
That way to can manually open up to 4 documents for editing on the same screen.
Let me know if it is not what you are looking for.
I know there is an option in Settings to open files in it’s own window. But I’m not talking about that. What I meant is to view files side by side in one window and not separate tabs to make new windows. As I wrote before “If 3 and 4 tiles are too much for onlyoffice then at least make 2 (tile vertically and tile horizontally), you can check screenshot named window pane 8 and window pane 9 for tile vertically and tile horizontally”. So, if 3 or 4 are too much then al least make two, to view two files vertically and horizontally. If this also can’t be made, then I will use what you suggested.
Thanks
Hello @nicesto
It is clearer for me now. Thank you.
We will take a closer look at this suggestion. I will inform you when ay news come up.
Hello @nicesto
We have registered your suggestion to add such possibility to sort editors windows with special keys in our internal tracker under the number 62283.
This feature will be added in one of the future releases of Desktop Editors.
