There are only couple of options to choose in the zoom values(from 50% to 500%). It would be better to give the option in zoom to set the zoom value which we want. For example 56%, 88%, 67% etc. I have named the screenshot “customize zoom value”.
Hey @nicesto
Thanks for the suggestions to upgrade the editor’s functionality.
We need some time to discuss the situation internally. I will update this thread when we have something to share.
Hey @nicesto
Thank you, we have added your suggestion (Option to customize zoom value) to internal tracksystem (internal number - 58256).
We’re working on it already.
