Option format cell left
the option to format cell with leading zero does not exist in onlyoffice, but in libreoffice it does. I can’t put image here.
OS version: Opensuse Tumblewed
App version: 7.1.1.57
Hello @cristianofurtado
I have increased your forum level, so you should be able to upload a compare screenshot to your post. Please provide us with details.
follow.
LibreOffice
OnlyOffice
OnlyOffice no have option. this option is important in brazil. Thanks
Thank you for your description, we are checking the situation.
I will update this post when we have something to share.
There’s a way to achieve your desired scenario. I prepared a short demonstration, please check it out:
I hope this is what you are looking for.
thanks. solved.
