Hi Ali and Alexandre,
Here a few more details of the issue after further investigation:
You could open a file on Android on different ways, either by opening the application firstly followed by opening the file, or by opening a file explorer and tapping on the file which should be opened. In that second case Android will offer the application(s) which are able to handle the file extension. In my case OnlyOffice or Collabora Office. Choosing OO let start OO followed by opening the file. So far so good.
In the first case the issue occurs very rarely, maybe 1 of 10 attempts.
But in the seconds case, and this is my normal workflow, 1 of 3 attempts are leading to the graphic error where I have to load the file a second time for correct presentation.
In the meantime I’ve created a record of my workflow showing the issue. The video is showing the following:
- starting the file manager of my LuckyCloud cloud storage space
- navigating to the file Test1.xlsx
- tabbing the file to open it
- Android offers CollaboraOffice and OnlyOffice
- Choosing OnlyOffice
- OO starts and is loading the file
- OO is presenting the Excel Spreadsheet and cell B8 is selected. Nevertheless another manual cell selection is not possible. Tabbing on another cell is only showing the green vertical icon bar
- further the video is showing my scrolling through the document. You could see different big white sections with missing cells and values. You see different scrolling attempts up and down, but the empty section remain empty
- then I close the spreadsheet and reload it via the same way - and surprise - the file is loaded and presented completely and I’m als able to select cells.
Here is the link to my record file: https://sync.luckycloud.de/f/79e73012a7304262b239/
Please understand that I’m not able to grant any guest access to my cloud storage space. If you would like to test the OO WebDAV access of LuckyCloud, you could arrange a 14day test account for free with LuckyCloud (https://luckycloud.de/en/preise-cloud-speicher-und-funktionen)
And in case you think the issue could belong to my Excel Spreadsheet, I could provide you with. Let me know.
Finally a have a proposal for improvement. My Excel spreadsheet contains a fix 1st column and 1st row. When scrolling through my document I would like to permanantly see these first column and row. But OO doesn’t support fix areas. Other Android Apps are able to support this function.
Cheers
Joerg
