Hi guys, I have OO installed on kubernetes with ingress upfront, problem is its now behind a double nginx proxy, I have it currently set as path /onlyoffice and every time I access certain urls, it will rewrite and drop me down to / and break the link
Can someone please advise if its possible to somehow resolve this other than editing the rewrites in OO directly ?
Thank you in advance !
Daniel
Document Server version: 7.3.3
OS: Kubernetes 1.23
Ingress/nginx: 1.94
Hi @dannik ![:wave: :wave:](https://forum.onlyoffice.com/images/emoji/twitter/wave.png?v=12)
Could you please clarify, do you have Ingress behind a proxy or proxy instead of Ingress?
It seems like you need to pass a header.
- If you’re using Nginx in front of Docs (without Ingress), here’s the configuration.
- If you’re using Ingress, you need to specify the subpath here .
Please note that Kubernetes cluster is mainly available and tested with Docs Enterprise/Developer since it provides high availability and failover resistance for cases when there is a high number of concurrent connections involved.
Scalability options are available only for commercial licenses. If you have purchased a commercial license, we recommend contacting us via Zendesk.
Also v.7.3 is outdated.
We recommend running update process timely, each new version contains fixes of known bugs and new features.
Thank you Nikolas!
Interesting variable path, was not aware of it … is that the new prefix variable in nginx I found in later versions of OO ?
I have OO deployed with its own proxy (nginx) behind k8s native ingress, so my issue is the path is being rewritten by OOs nginx, I can get around it only by modding the nginx config past deployment.
oh I looked at the helm example, well Im not using helm, Im building the deployment and ingress myself, I of course have the path set, but its not working when it hits certain rewrite locations such as:
rewrite ^/OfficeWeb(/apps/.*)$ $the_scheme://$the_host/7.3.3-49/web-apps$1 redirect;
this rewrite will drop the path and go to the root because of how its written, now I can manually add the path in here, but thats a manual post deployment action Id like to avoid
I did see a new feature called $prefix in the newer version, thinking of implementing that and then forwarding it from ingress
For issues regarding cluster installation, we recommend reaching out to support.
I would be glad if our community could assist in resolving your issue.
