Do you want to: Report a bug
OO Documents for Android does not work with the Samsung physical keyboard EF-DX815 on my Galaxy Tab S9 FE Plus Tablet:
- I can use the cursor keys to navigate in a document.
- but all the letter keys are not working
Api level: 34
App code: 611
App name: 8.3.0
Brand: samsung
Device: gts9fep
Device language: English
Model: SM-X616B
OS version: 5.15.153-android13-3-29539737
Version release: 14
Document Server Version: Hosted by service provider wolkesicher.de
Hello @ndilimani
Please note that newer version of the app is available in the market, update the app and check the situation again. I am looking forward to your feedback.
Thank you, Constantine, for the reply. The new version is installed on my tablet, the result is, however, the same: I can use the cursor keys, but pressing the letter keys has no effect.
Thank you for the reply. Does input work with virtual on-screen keyboard or it produces the same behavior?
Input works with the virtual on-screen keyboard but not with the EF-DX815 physical keyboard.
Does it happen with with all keyboard languages? By the way, do you use system default keyboard or a custom one?
The EF-DX815 is the official keyboard that came with ther tablet. I have the German version and use the QWERTZ format. The problems occurs irrespective which language I choose for the spell checker etc.
Thanks. We will try to reproduce the situation and analyze it from our end. I’ll let you know if any update comes up or in case I need more information.
Hello again @ndilimani
Unfortunately, we did not manage to reproduce the issue with keyboard input. Could you please specify currently used version of the app? Is it 8.3.2?
