OO Docs Snap installation behind reverse proxy
I have found the command to install Docs with Snap:
sudo snap install onlyoffice-ds
But I need it behinde a reverse proxy with a subdomain
https://onlyoffice.domain.com
I have installes onlyoffice with snap and the setup damadge my nginx reverse proxy.
So what parameter must I use, that snap works behind a reverse proxy?
Thank you!
Michael
Hello @MM300
Please take a look at this proxy config examples: Using ONLYOFFICE Docs behind the proxy - ONLYOFFICE
I hope it will be useful. If I misunderstood the situation please clarify it.
