onRequestSendNotify event not available on @onlyoffice/document-editor-angular
I am trying to use the onRequestSendNotify event.
Hello @subbu
This event is supported by the Angular component:
However, you cannot utilize it like component parameter as in this documentation:
https://api.onlyoffice.com/docs/docs-api/get-started/frontend-frameworks/angular/#onlyoffice-docs-angular-component-api
For instance, like that:
config: IConfig = {
    ... // all config
<document-editor
  id="docxForComments"
  documentServerUrl="http://documentserver/"
  [config]="config"
  [events_onRequestSendNotify]="onRequestSendNotify"
></document-editor>
Instead you should pass it in config.event parameter:
config: IConfig = {
    ... // all config
    events: {
          onRequestSendNotify: onRequestSendNotify
<document-editor
  [config]="config"
></document-editor>
Hope it helps.
