I looked information about Onlyoffice workspace community edition with RPM/DEB packages.
With that version, I can’t do updates and I can’t define https through the control panel. So, I guess I can do update with the help of terminal, and I can define https manually, isn’t it ?
Is there some restriction by using the rpm or deb version rather docker version ?
Thanks.
Hello @Bob
Please elaborate on this:
How exactly did you install Workspace and what prevents you from installing updates? Please share a link to the guide that you’ve followed to install Workspace and then some screenshots that demonstrate inability to use named features in Control Panel.
Additionally, please specify versions of all components currently installed and used. Take a screenshot of Update section of Control Panel.
