Document Server version: 6.4.2-6
Type of installation of the Document Server: deb/rpm
OS: Linux Ubuntu 20.04.03
Browser version: Chromium 94.0.4608.81, Firefox 93.0
My problem:
I install OnlyOffice Workspace Comunity Edition (DEB over script) for 2-3 users work with at EXCEL file.
Excel file is not big, ~ 500 string with text only.
And the work at this EXCEL document is very slowly (freezes after any change), but server CPU, memory and SSD disk are not load…
Please point me to the guide which you used for installation
Go to the host and run apt list --installed | grep onlyoffice, please show me the result.
Does the issue persist with this specific file only? If so, is it possible to provide us with file example? Also please record a videofile where you are reproducing the issue.
We reproduced the situation and added a bug to our internal tracksystem (bug number - 53715). When a solution is found we will add it as a fix in one of the next Document server versions.
