ONLYOFFICE spreadsheet size limitations
Hi,
I wanted to understand if there are any file size limitations while working with onlyoffice spreadsheets. I want to be able to load large amounts of excel data and interact/edit on it using onlyoffice spreadsheets integration.
I couldn’t find the specifications listed in the docs, can you list the limitations if any?
Thanks.
Hello.
Dear user, by default limit for uncompressed xlsx file is 300MB (you can try to extract your file as zip as see how much space it took).
If you use server edition of ONLYOFFICE you can find limits in /etc/onlyoffice/documentserver/default.json file.
