OnlyOffice Presentation: Insert gradient transparency
Hello there,
I am trying to create an gradient transparency at an Image on OnlyOffice Presentation.
Of course, I tried the Image Editor. There is no solution.
After That, I Googled and didn’t find a tip.
Could you help me?
(Eg. Transparency equally distributed at the edges of an Image)
Kind Regards
Dennis
Hello @Litigate4991.
Thank you for asking.
Select an image in your presentation < switch to plugins tab < then choose Photo editor
You can find more information in our help center.
Thank you.
Unfort. there is no opportunity to create equally distributed transparency at all adges.
Unfortunately we don’t support that feature. Thank you for your suggestion, we will forward your message to your developers.
