ONLYOFFICE Docs v7.3 released: enhanced forms, SmartArt, new security settings, Watch Window, and more
Onlyoffice/Nextcloud with https/caddy gives error when trying to open doc
Hi all, I’d really appreciate your help with Onlyoffice on newly installed Nextcloud with https. Everything else seems to be working fine with https.
OS: Debian 11.6
Nextcloud Hub 3 (25.0.3)
Community Document Server 0.1.13
ONLYOFFICE 7.6.8
The https is provided by Caddy with config below.
www.example.com {
reverse_proxy 192.168.0.102:80
I’m also attaching the error when trying to open document
Many thanks,
ioan
And Onlyoffice config is attached
Hello @ioan.stan
Community Document Server is the app developed by Nextcloud. With that said, we cannot guarantee stable functioning of this app and you have to contact Nextcloud support with detailed description of the problem.
Please see this: Community Document Server app in Nextcloud 18
If you want you can install official ONLYOFFICE Docs Community Edition on a dedicated server with this guide:
https://helpcenter.onlyoffice.com/installation/docs-community-index.aspx
Understood, thank you.
