ONLYOFFICE Docs v7.3 released: enhanced forms, SmartArt, new security settings, Watch Window, and more
OnlyOffice loading forever in Nextcloud
After a few docker container updates (I assume…), OnlyOffice stopped working. Whenever I open a document in Nextcloud, it shows a loading screen for some time and then shows the message “The connection to the server has been interrupted. Please reload the page.”.
I don’t know which update caused this and when. I’m running the latest version of both Nextcloud and OnlyOffice.
The configuration in the Nextcloud admin shows no error and seems to connect.
I tried recreating the Docker container without the volumes (from scratch). There’s no logs in err.log but there’s this in out.log:
[2023-02-02T23:31:04.573] [WARN] [localhost] [docId] [userId] nodeJS - Express server starting...
[2023-02-02T23:31:04.578] [WARN] [localhost] [docId] [userId] nodeJS - Failed to subscribe to plugin folder updates. When changing the list of plugins, you must restart the server. https://nodejs.org/docs/latest/api/fs.html#fs_availability
[2023-02-02T23:31:04.721] [WARN] [localhost] [docId] [userId] nodeJS - Express server listening on port 8000 in production-linux mode. Version: 7.3.0. Build: 184
[2023-02-02T23:31:37.602] [WARN] [localhost] [docId] [userId] nodeJS - Express server starting...
[2023-02-02T23:31:37.604] [WARN] [localhost] [docId] [userId] nodeJS - Failed to subscribe to plugin folder updates. When changing the list of plugins, you must restart the server. https://nodejs.org/docs/latest/api/fs.html#fs_availability
[2023-02-02T23:31:37.726] [WARN] [localhost] [docId] [userId] nodeJS - Express server listening on port 8000 in production-linux mode. Version: 7.3.0. Build: 184
[2023-02-02T23:31:57.891] [WARN] [localhost] [docId] [userId] nodeJS - <ref *2> IncomingMessage {
  _readableState: ReadableState {
    objectMode: false,
    highWaterMark: 16384,
    buffer: BufferList { head: null, tail: null, length: 0 },
    length: 0,
    pipes: [],
    flowing: null,
    ended: false,
    endEmitted: false,
    reading: false,
    sync: true,
    needReadable: false,
    emittedReadable: false,
    readableListening: false,
    resumeScheduled: false,
    errorEmitted: false,
    emitClose: true,
    autoDestroy: false,
    destroyed: false,
    errored: null,
    closed: false,
    closeEmitted: false,
    defaultEncoding: 'utf8',
    awaitDrainWriters: null,
    multiAwaitDrain: false,
    readingMore: true,
    dataEmitted: false,
    decoder: null,
    encoding: null,
    [Symbol(kPaused)]: null
  _events: [Object: null prototype] { end: [Function: clearRequestTimeout] },
  _eventsCount: 1,
  _maxListeners: undefined,
  socket: <ref *1> Socket {
    connecting: false,
    _hadError: false,
    _parent: null,
    _host: null,
      objectMode: false,
      length: 0,
      pipes: [],
      flowing: true,
      ended: false,
      endEmitted: false,
      reading: true,
      sync: false,
      needReadable: true,
      emitClose: false,
      autoDestroy: false,
      destroyed: false,
      errored: null,
      closed: false,
      readingMore: false,
      dataEmitted: false,
      decoder: null,
      encoding: null,
      [Symbol(kPaused)]: false
      end: [Array],
      timeout: [Function: socketOnTimeout],
      data: [Function: bound socketOnData],
      error: [Function: socketOnError],
      close: [Array],
      drain: [Function: bound socketOnDrain],
      resume: [Function: onSocketResume],
      pause: [Function: onSocketPause]
    _eventsCount: 8,
    _writableState: WritableState {
      objectMode: false,
      finalCalled: false,
      needDrain: false,
      ending: false,
      ended: false,
      finished: false,
      destroyed: false,
      decodeStrings: false,
      length: 0,
      writing: false,
      corked: 0,
      sync: true,
      bufferProcessing: false,
      onwrite: [Function: bound onwrite],
      writecb: null,
      writelen: 0,
      afterWriteTickInfo: null,
      buffered: [],
      bufferedIndex: 0,
      allBuffers: true,
      allNoop: true,
      pendingcb: 0,
      prefinished: false,
      emitClose: false,
      autoDestroy: false,
      errored: null,
      closed: false,
      closeEmitted: false
    allowHalfOpen: true,
    _sockname: null,
    _pendingData: null,
    _pendingEncoding: '',
    server: Server {
      maxHeaderSize: undefined,
      insecureHTTPParser: undefined,
      _events: [Object: null prototype],
      _eventsCount: 5,
      _connections: 1,
      _handle: [TCP],
      _usingWorkers: false,
      _workers: [],
      _unref: false,
      pauseOnConnect: false,
      httpAllowHalfOpen: false,
      timeout: 0,
      keepAliveTimeout: 5000,
      maxHeadersCount: null,
      headersTimeout: 60000,
      requestTimeout: 0,
      _connectionKey: '6::::8000',
      [Symbol(IncomingMessage)]: [Function: IncomingMessage],
      [Symbol(ServerResponse)]: [Function: ServerResponse],
      [Symbol(kCapture)]: false,
      [Symbol(async_id_symbol)]: 225
    _server: Server {
      _eventsCount: 5,
      _connections: 1,
      _handle: [TCP],
      _workers: [],
      _unref: false,
      timeout: 0,
      requestTimeout: 0,
    parser: HTTPParser {
      '0': [Function: bound setRequestTimeout],
      '1': [Function: parserOnHeaders],
      '2': [Function: parserOnHeadersComplete],
      '3': [Function: parserOnBody],
      '4': [Function: parserOnMessageComplete],
      '5': [Function: bound onParserExecute],
      '6': [Function: bound onParserTimeout],
      _headers: [],
      _url: '',
      socket: [Circular *1],
      incoming: [Circular *2],
      outgoing: null,
      maxHeaderPairs: 2000,
      _consumed: true,
      onIncoming: [Function: bound parserOnIncoming],
      [Symbol(resource_symbol)]: [HTTPServerAsyncResource]
    on: [Function: socketListenerWrap],
    addListener: [Function: socketListenerWrap],
    prependListener: [Function: socketListenerWrap],
    _paused: false,
    _httpMessage: ServerResponse {
      _eventsCount: 1,
      outputData: [],
      outputSize: 0,
      writable: true,
      destroyed: false,
      _last: false,
      chunkedEncoding: false,
      shouldKeepAlive: false,
      _defaultKeepAlive: true,
      useChunkedEncodingByDefault: true,
      sendDate: true,
      _removedConnection: false,
      _removedContLen: false,
      _removedTE: false,
      _contentLength: null,
      _hasBody: true,
      _trailer: '',
      finished: false,
      _headerSent: false,
      _header: null,
      _keepAliveTimeout: 5000,
      _onPendingData: [Function: bound updateOutgoingData],
      _sent100: false,
      _expect_continue: false,
      [Symbol(kNeedDrain)]: false,
      [Symbol(corked)]: 0,
      [Symbol(kOutHeaders)]: null
    [Symbol(async_id_symbol)]: 229,
    [Symbol(kHandle)]: TCP {
      reading: true,
      onconnection: null,
      _consumed: true,
      [Symbol(owner_symbol)]: [Circular *1]
    [Symbol(kSetNoDelay)]: false,
    [Symbol(lastWriteQueueSize)]: 0,
    [Symbol(timeout)]: null,
    [Symbol(kBuffer)]: null,
    [Symbol(kBufferCb)]: null,
    [Symbol(kBufferGen)]: null,
    [Symbol(kBytesRead)]: 0,
    [Symbol(kBytesWritten)]: 0,
    [Symbol(RequestTimeout)]: undefined
  httpVersionMajor: 1,
  httpVersionMinor: 1,
  httpVersion: '1.1',
  complete: false,
  headers: {
    host: 'office.xxxxxxxx.me',
    connection: 'close',
    'x-forwarded-host': 'office.xxxxxxx.me',
    'x-forwarded-proto': 'https',
    'x-forwarded-for': '10.0.0.1, 10.0.0.2',
    'x-real-ip': '10.0.0.1',
    pragma: 'no-cache',
    'cache-control': 'no-cache',
    'user-agent': 'Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/109.0.0.0 Safari/537.36',
    origin: 'https://office.xxxxxxxx.me',
    'sec-websocket-version': '13',
    'accept-encoding': 'gzip, deflate, br',
    'accept-language': 'en,pt-PT;q=0.9,pt;q=0.8,en-US;q=0.7,es;q=0.6,de;q=0.5,fr;q=0.4,da;q=0.3,la;q=0.2,gl;q=0.1',
    'sec-websocket-key': 'baoP7HfYvUSA1m7x5MY9pg==',
    'sec-websocket-extensions': 'permessage-deflate; client_max_window_bits'
  rawHeaders: [
    'Host',
    'Connection',
    'close',
    'X-Forwarded-Host',
    'X-Forwarded-Proto',
    'https',
    'X-Forwarded-For',
    'X-Real-IP',
    '10.0.0.1',
    'Pragma',
    'no-cache',
    'Cache-Control',
    'no-cache',
    'User-Agent',
    'Origin',
    'Sec-WebSocket-Version',
    '13',
    'Accept-Encoding',
    'Accept-Language',
    'Sec-WebSocket-Key',
    'Sec-WebSocket-Extensions',
  trailers: {},
  rawTrailers: [],
  aborted: false,
  upgrade: false,
  url: '/doc/3139224055/c/?EIO=4&transport=websocket',
  method: 'GET',
  statusCode: null,
  statusMessage: null,
  client: <ref *1> Socket {
    connecting: false,
    _hadError: false,
    _parent: null,
    _host: null,
      objectMode: false,
      length: 0,
      pipes: [],
      flowing: true,
      ended: false,
      endEmitted: false,
      reading: true,
      sync: false,
      needReadable: true,
      emitClose: false,
      autoDestroy: false,
      destroyed: false,
      errored: null,
      closed: false,
      readingMore: false,
      dataEmitted: false,
      decoder: null,
      encoding: null,
      end: [Array],
      close: [Array],
[2023-02-02T23:31:57.897] [WARN] [localhost] [docId] [userId] nodeJS - 3
[2023-02-02T23:31:57.898] [WARN] [localhost] [docId] [userId] nodeJS - Bad request
[2023-02-02T23:31:57.898] [WARN] [localhost] [docId] [userId] nodeJS - { name: 'TRANSPORT_HANDSHAKE_ERROR' }
[2023-02-02T23:31:58.467] [WARN] [localhost] [docId] [userId] nodeJS - <ref *2> IncomingMessage {
I was missing the proxy_set_header Upgrade $http_upgrade; header in NGINX. Apparently this is required now.
Hello @mignz
I do believe that the issue was solved already.
But if it wasn’t then, please check out the available NGINX configuration examples on our GitHub:
https://github.com/ONLYOFFICE/document-server-proxy/tree/master/nginx
