ONLYOFFICE Healthcheck 502 Error on Proot-distro Debian ARM64
My Android phone is not rooted and I installed Debian 12 Bookworm using proot-distro install debian in Termux
Referencing OnlyOffice’s official guide on “Installing ONLYOFFICE Docs Community Edition on Debian systems for the 64-bit ARM architecture”:
https://helpcenter.onlyoffice.com/installation/docs-community-install-ubuntu-arm64.aspx
My device boasts 30GB of RAM and a 1TB hard drive, fully meeting the requirements for ARM64 architecture.
Following the official tutorial, I have installed the necessary dependencies, ensuring all versions meet the specified criteria:
  • PostgreSQL 17.2
  • NGINX 1.22.1
  • libstdc++6 12.2.0
  • RabbitMQ 3.13
Given that RabbitMQ 3.13 requires Erlang 26, I have also installed Erlang 26 to ensure compatibility and optimal performance.
RabbitMQ status is normal:
service rabbitmq-server status
I can log in to RabbitMQ by visiting:
http://localhost:15672
Nginx status is normal:
service nginx status
This indicates that Nginx is running properly.
PostgreSQL status is also normal:
su - postgres -c '/usr/lib/postgresql/17/bin/pg_ctl -D /var/lib/postgresql/17/main -l logfile start'
After confirming that all dependencies are functioning correctly, I proceeded with installing the document server according to the official guide. During the installation, I encountered the following warning:
Warning: The home directory `/var/www/onlyoffice/documentserver'
And an error:
installed onlyoffice-documentserver package post-installation script subprocess returned error exit status 1
ls -ld /var/www/onlyoffice/documentserver
The directory owner is the root user.
debconf-show onlyoffice-documentserver
onlyoffice/db-pwd:(password omitted)
onlyoffice/rabbitmq-pwd:(password omitted)
onlyoffice/db-name: onlyoffice
onlyoffice/db-port:
onlyoffice/rabbitmq-user: guest
onlyoffice/db-type: postgres
onlyoffice/jwt-secret:y27Jx****
onlyoffice/example-port:3000
onlyoffice/jwt-enabled:true
onlyoffice/jwt-header: Authorization
onlyoffice/plugins-enabled: true
onlyoffice/rabbitmq-proto: amqp
onlyoffice/docservice-port:8000
onlyoffice/db-user:
onlyoffice/onlyoffice/remove-db: false
onlyoffice/db-host: localhost
onlyoffice/wopi-enabled:false
onlyoffice/ds-port:8088
onlyoffice/rabbitmq-host: localhost
onlyoffice/cluster-mode: false
i can log in to the ONLYOFFICE welcome page using:
https://mydomain.com:4443
When I put`https://mydomain.com:4443` in the ONLYOFFICE plugin for Nextcloud to connect to my ONLYOFFICE Docs, a 502 error occurs.
'GET
https://zvkai.com:4443/healthcheck
resulted in a `502 Bad Gateway
response:
502 Bad Gateway
ngin (truncated..)
I tried setting the WOPI enable to true in the local.json file, but it did not resolve the issue.
nano /etc/onlyoffice/documentserver/local.json
Could someone please advise on how to fix this problem? I have spent two weeks trying various solutions without success.
Note: Termux does not support Docker and Snapd, so please do not suggest installation methods involving Docker or Snapd for the document server.
Hello @Tiew, Docs installation on Android (even using Debian in Termux) won’t work. Please install on a server instead
Why is that? I believe that OnlyOffice Docs can be installed on the Debian environment in Termux. If it’s possible, could you please tell me how to fix this minor issue: “installed onlyoffice-documentserver package post-installation script subprocess returned error exit status 1”?
You see, Nginx, PostgreSQL, and RabbitMQ-server, which all require root permissions, have been successfully installed. i.had also successfully installed nextcloud server on Debian Termux ,There’s no reason why onlyoffice-documentserver should fail to install.
We haven’t tested this type of installation on our side, do not officially support it and thus can give no advice regarding Android installation of Docs in Termux. We strongly recommend to install on a server machine
