ONLYOFFICE Docs 8.3 released: PDF stamps, Merge Shapes, support for Pages, Keynote, Numbers, HWP formats, and more
The latest version of our online editors is already available with around 30 new features and multiple bug fixes across the suite. Read on to discover all the updates.
Support for Apple iWork and Hancom Office file formats
The following file formats are now supported:
  • Apple iWork formats: Pages, Keynote, Numbers
  • Hancom Office formats: .hwp, .hwpx
Just open any files of the specified formats in your ONLYOFFICE to check yourself that everything works properly and the formatting is preserved.
If you need to edit such files, they will be converted and saved to OOXML formats (DOCX, PPTX, XLSX). However in this case, full formatting compliance is not guaranteed.
No matter what file you’re working with, ONLYOFFICE has you covered!
Improved RTL support
We are constantly improving localization of ONLYOFFICE Docs to make our suite accessible to all users, all over the world. Refining RTL support is one of the most important directions for us. With this release, we added:
  • ability to change the default sheet direction;*
  • ability to change the paragraph direction* (LTR ⇌ RTL) in text documents;
  • fixed display of non-printable characters for RTL paragraphs in text documents;
  • RTL interface support for the embedded viewer.
*Where to find: Sheet -> File tab -> Advanced settings / Document -> Home tab -> Text direction
What’s new in PDF Editor
Stamps. Add a professional touch to your contracts, agreements, and other PDF files with stamps.
Where to find: Comment tab -> Stamp
Enhanced collaboration. Undo your last actions during real-time co-editing sessions in PDF files without disrupting your team’s workflow.
Where to find: Top toolbar -> Undo
Multiselect for PDF pages. Enjoy the convenience of selecting multiple pages at once to rearrange or delete them.
  • Using the Ctrl key: add/remove a page to the selection.
  • Using the Shift key: select a range.
Quick panel for editing annotations. Change the highlight color, add a comment, or remove an annotation in just several clicks.
Where to find: Hover over the inserted annotation
Opacity. Adjust opacity of the highlight color when adding or editing annotations.
Where to find: Highlight color -> Opacity
What’s new in spreadsheets
Enhanced collaboration. Like for the PDF Editor, it’s now possible to undo last actions during real-time co-editing. Collaboration in sheets has never been smoother.
AutoUpdate for external links. Automatically update data from the linked sources to ensure that important numbers are up to date as possible.
Where to find: Data tab -> External links
More options for AutoFilling cells. Fill days, weekdays, months, years.
Where to find: Series
Moreover, the latest version of the Spreadsheet Editor brings:
  • ability to open and save calculated items in Pivot Tables;
  • updated function wizard with descriptions of the function arguments to get a hint;
  • AutoDetect of delimiters by the file text in the dialog of CSV opening parameters;
  • Ability to show/hide horizontal and vertical scroll bar.
What’s new in presentations
Design tab. Meet the new tab for more intuitive working with your slides. Seamlessly apply styles, change color schemes, and adjust the slide size.
Where to find: Design tab
Drawing during slideshow. Draw directly on the canvas in the slideshow or presenter mode using the pen and highlighter tools.
Where to find: Slideshow / Presenter mode
Moreover, make use of the following novelties in the Presentation Editor:
  • renaming Slide Master;
  • Show from Beginning option available via the top Quick Access Toolbar;
  • Hand and Select buttons available in the presentation viewer.
All editors: Merge shapes
Unleash your creativity with the Merge shapes feature – combine them in seconds to create custom visuals.
  • Union
  • Combine
  • Fragment
  • Intersect
  • Subtract
Where to find: Context menu -> Merge shapes
More useful enhancements
  • Ability to combine and compare text documents on the character or word level.
  • Improved usability when working with protected text documents.
  • Ability to toggle field codes.
  • Reset crop for images is now available from the right panel and context menu.
Localization
Besides, in version 8.3, you will find:
  • Albanian localization (sq-AL);
  • More languages available in the list of exceptions for Text AutoCorrect.
We always welcome contributors and translators to our community. Join us to help others use the editors in their native languages and get a reward for your efforts. Check the details
How to use new features
Watch our free detailed webinar to learn how to work with the new features:
Get ONLYOFFICE Docs 8.3
Download the self-hosted version of ONLYOFFICE Docs 8.3:
DOWNLOAD NOW
In the cloud solutions, the new version will be available a bit later. Stay tuned!
Useful links
Full changelog
ONLYOFFICE Docs Enterprise
ONLYOFFICE Docs Developer
Help Center: user guides
Originally published at: ONLYOFFICE Docs 8.3 released: PDF stamps, Merge Shapes, support for Pages, Keynote, Numbers, HWP formats, and more | ONLYOFFICE Blog
