OnlyOffice Connector for Liferay : deprecated classes and method
Hi,
The OnlyOffice Connector (2.2) for Liferay is broken on versions of Liferay Portal greater than 7.4.GA21.
This is due to the use of many deprecated/retired classes and methods in the connector.
Exemple :
ModelResourcePermissionHelper is deprecated and retired since 7.4ga21. But still used in the connector.
So it generates error on document library like this :
“java.lang.ClassNotFoundException: com.liferay.portal.kernel.security.permission.resource.ModelResourcePermissionHelper cannot be found by onlyoffice.integration.web_2.2.0”
You should use ModelResourcePermissionUtil.
But that’s not the only one. There is changes in DLApp methods (create/update).
Especially, ga39 have many removal of so called “unused method” that it is used on Action Menu customisations in the connector
So the actual releases are not eligibles for Lifeay 7.4ga21+…
My asks are :
  • Is there a roadmap for a next version of the connector, as I can’t see any code update since last April ?
  • would you accept our contributions on the project (developing, testing) ?
  • Or should we fork it to correct it ?
We have great experiences on Liferay portals, so we can bring our skills on the Liferay Connector project.
Regards
Hello @christophe.cariou
We are checking the described situation. We have run a quick test and it seems that you are right, there’s an issue with v.7.4.3.2-ga21.
I will notify you when we get any news.
Sorry, we don’t have public roadmap.
You can create pullrequest on GitHub. As far as I understand you created the issue earlier with the same request here:Many deprecated methods and classes used · Issue #36 · ONLYOFFICE/onlyoffice-liferay · GitHub
We can confirm that there’s the issue with Liferay.
We are going to fix it with the next version of connector app.
Thank you for pointing us to this situation!
Hello @Alexandre ,
great ! Waiting for the next version.
Regards
Christophe
