Onlyoffice community under docker does not run
I am trying to install onlyoffice workspace with Docker and I have some problems. Probably I have deleted something I shouldn’t have deleted.
Host OS: Ubuntu 24.04.1 LTS
Docker version: Docker version 27.3.1, build ce12230
Docker compose version: Docker Compose version v2.29.7
MySQL version: mysql Ver 8.0.36 for Linux on x86_64 (MySQL Community Server - GPL)
Steps I followed:
For my MySQL server (external host):
CREATE DATABASE onlyoffice_db;
grant all privileges on onlyoffice_db.* to ‘onlyoffice_user’@‘%’;
flush privileges;
In the Ubuntu Host with Docker and Docker compose installed:
git clone (git url for ONLYOFFICE/Docker-CommunityServer)
cd Docker-CommunityServer
nano docker-compose.yml
Because I do not want the mailserver and I have already a MySQL server, I have made some modifications in the docker-compose.yml
> version: '3'
> services:
>   onlyoffice-community-server:
>     container_name: onlyoffice-community-server
>     image: onlyoffice/communityserver:12.6.0.1900
>     depends_on:
>      - onlyoffice-document-server
>      - onlyoffice-elasticsearch
>     environment:
>      - ONLYOFFICE_CORE_MACHINEKEY=XXXXXXXXXX
>      - CONTROL_PANEL_PORT_80_TCP=80
>      - CONTROL_PANEL_PORT_80_TCP_ADDR=10.0.15.103
>      - DOCUMENT_SERVER_PORT_80_TCP_ADDR=10.0.15.101
>      - DOCUMENT_SERVER_JWT_ENABLED=true
>      - DOCUMENT_SERVER_JWT_SECRET=XXXXXXXXXX
>      - DOCUMENT_SERVER_JWT_HEADER=AuthorizationJwt
>      - MYSQL_SERVER_DB_NAME=onlyoffice_db
>      - MYSQL_SERVER_HOST=10.0.12.10
>      - MYSQL_SERVER_USER=onlyoffice_user
>      - MYSQL_SERVER_PASS=XXXXXXXXXX
>      - ELASTICSEARCH_SERVER_HOST=10.0.15.102
>      - ELASTICSEARCH_SERVER_HTTPPORT=9200
>     ports:
>      - '80:80'
>      - '443:443'
>      - '5222:5222'
>     stdin_open: true
>     tty: true
>     restart: always
>     privileged: true
>     cgroup: host
>     volumes:
>      - community_data:/var/www/onlyoffice/Data
>      - community_log:/var/log/onlyoffice
>      - community_letsencrypt:/etc/letsencrypt
>      - document_data:/var/www/onlyoffice/DocumentServerData
>      - /sys/fs/cgroup:/sys/fs/cgroup:rw
>      - ./certs:/var/www/onlyoffice/Data/certs
>     networks:
>         DockerVLAN:
>             ipv4_address: 10.0.15.100
>   onlyoffice-document-server:
>     container_name: onlyoffice-document-server
>     image: onlyoffice/documentserver:8.1
>     stdin_open: true
>     tty: true
>     restart: always
>     environment:
>      - JWT_ENABLED=true
>      - JWT_SECRET=XXXXXXXXXX
>      - JWT_HEADER=AuthorizationJwt
>     expose:
>       - '80'
>       - '443'
>     volumes:
>        - document_data:/var/www/onlyoffice/Data
>        - document_log:/var/log/onlyoffice
>        - ./document_fonts:/usr/share/fonts/truetype/custom
>        - document_forgotten:/var/lib/onlyoffice/documentserver/App_Data/cache/files/forgotten
>     networks:
>         DockerVLAN:
>             ipv4_address: 10.0.15.101
>   onlyoffice-elasticsearch:
>     image: onlyoffice/elasticsearch:7.16.3
>     container_name: onlyoffice-elasticsearch
>     restart: always
>     environment:
>       - discovery.type=single-node
>       - bootstrap.memory_lock=true
>       - "ES_JAVA_OPTS=-Xms1g -Xmx1g -Dlog4j2.formatMsgNoLookups=true"
>       - "indices.fielddata.cache.size=30%"
>       - "indices.memory.index_buffer_size=30%"
>       - "ingest.geoip.downloader.enabled=false"
>     ulimits:
>       memlock:
>         soft: -1
>         hard: -1
>       nofile:
>         soft: 65535
>         hard: 65535
>     volumes:
>       - es_data:/usr/share/elasticsearch/data
>     expose:
>       - "9200"
>       - "9300"
>     networks:
>         DockerVLAN:
>             ipv4_address: 10.0.15.102
>   onlyoffice-control-panel:
>     container_name: onlyoffice-control-panel
>     depends_on:
>      - onlyoffice-community-server
>     image: onlyoffice/controlpanel:3.5.2.530
>     environment:
>     expose:
>       - '80'
>       - '443'
>     restart: always
>     volumes:
>       - /var/run/docker.sock:/var/run/docker.sock
>       - controlpanel_data:/var/www/onlyoffice/Data
>       - controlpanel_log:/var/log/onlyoffice
>     stdin_open: true
>     tty: true
>     networks:
>         DockerVLAN:
>             ipv4_address: 10.0.15.103
> networks:
>     DockerVLAN:
>         external: true
> volumes:
>   document_data:
>   document_log:
>   document_forgotten:
>   community_data:
>   community_log:
>   controlpanel_data:
>   controlpanel_log:
>   es_data:
Then, when I run the docker compose all looks fine and the containers are up.
Here you can see the community server logs:
> root@onlyoffice:/docker/Docker-CommunityServer# docker logs onlyoffice-community-server --follow
> + echo '##########################################################'
> + echo '#########  Start container configuration  ################'
> + SERVER_HOST=
> + APP_DIR=/var/www/onlyoffice
> + APP_DATA_DIR=/var/www/onlyoffice/Data
> + APP_INDEX_DIR=/var/www/onlyoffice/Data/Index/v7.16.3
> + APP_PRIVATE_DATA_DIR=/var/www/onlyoffice/Data/.private
> + APP_SERVICES_DIR=/var/www/onlyoffice/Services
> + APP_CONFIG_DIR=/etc/onlyoffice/communityserver
> + APP_SQL_DIR=/var/www/onlyoffice/Sql
> + APP_ROOT_DIR=/var/www/onlyoffice/WebStudio
> + APP_APISYSTEM_DIR=/var/www/onlyoffice/ApiSystem
> + APP_GOD_DIR=/etc/god/conf.d
> + APP_MONOSERVER_PATH=/lib/systemd/system/monoserve.service
> + APP_HYPERFASTCGI_PATH=/etc/hyperfastcgi/onlyoffice
> + APP_MONOSERVE_COUNT=1
> + APP_MODE=SERVER
> + APP_CRON_DIR=/etc/cron.d
> + APP_CRON_PATH=/etc/cron.d/onlyoffice
> + LICENSE_FILE_PATH=/var/www/onlyoffice/DocumentServerData/license.lic
> ++ ip -o -f inet addr show
> ++ head -1
> ++ awk '/scope global/ {print $4}'
> + DOCKER_APP_SUBNET=10.0.15.100/24
> ++ awk '/inet / {gsub(/\/.*/,"",$2); print $2}'
> ++ head -1
> ++ ip addr show eth0
> + DOCKER_CONTAINER_IP=10.0.15.100
> + DOCKER_CONTAINER_NAME=onlyoffice-community-server
> + DOCKER_DOCUMENT_SERVER_CONTAINER_NAME=onlyoffice-document-server
> + DOCKER_ENABLED=true
> +++ dirname /app/run-community-server.sh
> ++ cd /app
> ++ pwd
> + DIR=/app
> + NGINX_CONF_DIR=/etc/nginx/sites-enabled
> ++ cat /proc/cpuinfo
> ++ grep -i processor
> ++ awk '{print $1}'
> ++ wc -l
> + CPU_PROCESSOR_COUNT=4
> ++ ulimit -n
> + NGINX_WORKER_CONNECTIONS=1048576
> + NGINX_WORKER_PROCESSES=1
> + SERVICE_SSO_AUTH_HOST_ADDR=10.0.15.103
> ++ sudo sed -n '/"core.machinekey"/s!.*value\s*=\s*"\([^"]*\)".*!\1!p' /var/www/onlyoffice/WebStudio/web.appsettings.config
> + DEFAULT_APP_CORE_MACHINEKEY=qvkvZMFNHzB1
> + IS_UPDATE=false
> + WORKSPACE_ENTERPRISE=false
> + '[' '!' -e /var/www/onlyoffice/Data/.private/machinekey ']'
> + mkdir -p /var/www/onlyoffice/Data/.private
> + APP_CORE_MACHINEKEY=XXXXXXXXXXX
> + echo XXXXXXXXXXX
> ++ sudo sed -n '/"version.number"/s!.*value\s*=\s*"\([^"]*\)".*!\1!p' /var/www/onlyoffice/WebStudio/web.appsettings.config
> + RELEASE_DATE=12.6.0.1900
> ++ CreateAuthToken 12.6.0.1900 XXXXXXXXXXX
> ++ local pkey=12.6.0.1900
> +++ echo -n XXXXXXXXXXX
> ++ local machinekey=XXXXXXXXXXX
> ++ local a=1
> ++ local LIMIT=10
> ++ '[' 1 -le 10 ']'
> +++ date +%Y%m%d%H%M%S
> ++ local now=20241120135818
> +++ echo -n -e '20241120135818\n12.6.0.1900'
> +++ openssl dgst -sha1 -binary -mac HMAC -macopt key:XXXXXXXXXXX
> ++ local 'authkey=�Cu�*-E:'\''�$����
> h'
> +++ echo -n '�Cu�*-E:'\''�$����
> h'
> +++ base64
> ++ authkey=4EN1jyotRToUJ/ckircRqa0MH2g=
> ++ local 'result=ASC 12.6.0.1900:20241120135818:4EN1jyotRToUJ/ckircRqa0MH2g='
> ++ a=2
> +++ echo '"ASC' '12.6.0.1900:20241120135818:4EN1jyotRToUJ/ckircRqa0MH2g="'
> +++ grep ==
> ++ '[' -z '' ']'
> ++ echo 'ASC 12.6.0.1900:20241120135818:4EN1jyotRToUJ/ckircRqa0MH2g='
> ++ exit 0
> + RELEASE_DATE_SIGN='ASC 12.6.0.1900:20241120135818:4EN1jyotRToUJ/ckircRqa0MH2g='
> + sed -i '/version.release-date.sign/s!value="[^"]*"!value=\"ASC 12.6.0.1900:20241120135818:4EN1jyotRToUJ/ckircRqa0MH2g=\"!g' /var/www/onlyoffice/WebStudio/web.appsettings.config
> ++ head -n 1 /var/www/onlyoffice/Data/.private/release_date
> head: cannot open '/var/www/onlyoffice/Data/.private/release_date' for reading: No such file or directory
> + PREV_RELEASE_DATE=
> + '[' 12.6.0.1900 '!=' '' ']'
> + echo 12.6.0.1900
> + IS_UPDATE=true
> + chmod -R 444 /var/www/onlyoffice/Data/.private
> + cat /proc/1/cgroup
> + grep -qE 'docker|lxc|kubepods|libpod'
> + '[' '!' -d /etc/nginx/sites-enabled ']'
> + '[' '!' -d /var/www/onlyoffice/DocumentServerData ']'
> + NGINX_ROOT_DIR=/etc/nginx
> + VALID_IP_ADDRESS_REGEX='^(([0-9]|[1-9][0-9]|1[0-9]{2}|2[0-4][0-9]|25[0-5])\.){3}([0-9]|[1-9][0-9]|1[0-9]{2}|2[0-4][0-9]|25[0-5])$'
> + LOG_DEBUG=
> + LOG_DIR=/var/log/onlyoffice/
> + APP_HTTPS=false
> + SSL_CERTIFICATES_DIR=/var/www/onlyoffice/Data/certs
> + SSL_CERTIFICATE_PATH=/var/www/onlyoffice/Data/certs/onlyoffice.crt
> + SSL_KEY_PATH=/var/www/onlyoffice/Data/certs/onlyoffice.key
> + SSL_CERTIFICATE_PATH_PFX=/var/www/onlyoffice/Data/certs/onlyoffice.pfx
> + SSL_CERTIFICATE_PATH_PFX_PWD=onlyoffice
> + SSL_DHPARAM_PATH=/var/www/onlyoffice/Data/certs/dhparam.pem
> + SSL_VERIFY_CLIENT=off
> + SSL_OCSP_CERTIFICATE_PATH=/var/www/onlyoffice/Data/certs/stapling.trusted.crt
> + CA_CERTIFICATES_PATH=/var/www/onlyoffice/Data/certs/ca.crt
> + APP_HTTPS_HSTS_ENABLED=true
> + APP_HTTPS_HSTS_MAXAGE=63072000
> + SYSCONF_TEMPLATES_DIR=/app/config
> + mkdir -p /app/config/nginx
> + SYSCONF_TOOLS_DIR=/app/assets/tools
> + APP_SERVICES_INTERNAL_HOST=
> + APP_SERVICES_EXTERNAL=false
> + DOCUMENT_SERVER_ENABLED=false
> + DOCUMENT_SERVER_JWT_ENABLED=true
> + DOCUMENT_SERVER_JWT_SECRET=XXXXXXXXXXX
> + DOCUMENT_SERVER_JWT_HEADER=AuthorizationJwt
> + DOCUMENT_SERVER_HOST=
> + DOCUMENT_SERVER_PROTOCOL=http
> + DOCUMENT_SERVER_API_URL=
> + DOCUMENT_SERVER_HOST_IP=
> + CONTROL_PANEL_ENABLED=false
> + MAIL_SERVER_ENABLED=false
> + set +x
> + mkdir -p /var/www/onlyoffice/Data/certs/.well-known/acme-challenge
> + '[' 10.0.15.100/24 ']'
> ++ normalize_subnet 10.0.15.100/24
> ++ local 'IPRE=\([0-9]\+\)\.\([0-9]\+\)\.\([0-9]\+\)\.\([0-9]\+\)'
> +++ echo 10.0.15.100/24
> +++ sed -ne 's:]\+\)\.\([0-9]\+\)\.\([0-9]\+\)\.\([0-9]\+\)/.*$:\1 \2 \3 \4:p'
> ++ IP=('10' '0' '15' '100')
> ++ local IP
> +++ sed -ne 's:/\([0-9]\+\)\.\([0-9]\+\)\.\([0-9]\+\)\.\([0-9]\+\)$:\1 \2 \3 \4:p'
> ++ MASK=()
> ++ local MASK
> ++ '[' 0 -ne 4 ']'
> +++ sed -ne 's:0-9]\+\)$:\1:p'
> ++ BITCNT=('24')
> ++ local BITCNT
> ++ BITCNT=4294967040
> ++ (( I=0 ))
> ++ (( I<4 ))
> ++ MASK[$I]=255
> ++ (( I++  ))
> ++ (( I<4 ))
> ++ MASK[$I]=255
> ++ (( I++  ))
> ++ (( I<4 ))
> ++ MASK[$I]=255
> ++ (( I++  ))
> ++ (( I<4 ))
> ++ MASK[$I]=0
> ++ (( I++  ))
> ++ (( I<4 ))
> ++ NETWORK=()
> ++ local NETWORK
> ++ (( I=0 ))
> ++ (( I<4 ))
> ++ NETWORK[$I]=10
> ++ (( I++  ))
> ++ (( I<4 ))
> ++ NETWORK[$I]=0
> ++ (( I++  ))
> ++ (( I<4 ))
> ++ NETWORK[$I]=15
> ++ (( I++  ))
> ++ (( I<4 ))
> ++ NETWORK[$I]=0
> ++ (( I++  ))
> ++ (( I<4 ))
> +++ sed -ne 's:*/\([0-9]\+\)$:\1:p'
> ++ local IP_MASK=24
> ++ echo 10.0.15.0/24
> + DOCKER_APP_SUBNET=10.0.15.0/24
> + check_partnerdata
> + PARTNER_DATA_FILE=/var/www/onlyoffice/Data/json-data.txt
> + '[' -f /var/www/onlyoffice/Data/json-data.txt ']'
> + re='[0-9]+$'
> + [[ 1 =~ [0-9]+$ ]]
> + '[' '!' -f /proc/net/if_inet6 ']'
> + cp /etc/nginx/includes/onlyoffice-communityserver-nginx.conf.template /etc/nginx/nginx.conf
> + sed 's/^worker_processes.*/worker_processes 1;/' -i /etc/nginx/nginx.conf
> + sed 's/worker_connections.*/worker_connections 1048576;/' -i /etc/nginx/nginx.conf
> + cp /etc/nginx/includes/onlyoffice-communityserver-common-init.conf.template /etc/nginx/sites-enabled/onlyoffice
> + '[' -f /var/www/onlyoffice/Data/certs/onlyoffice.crt -a -f /var/www/onlyoffice/Data/certs/onlyoffice.key ']'
> + sed '/{{SSL_CERTIFICATE_PATH}}/d' -i /etc/nginx/sites-enabled/onlyoffice
> + sed '/{{SSL_KEY_PATH}}/d' -i /etc/nginx/sites-enabled/onlyoffice
> + sed '/listen\s*443/d' -i /etc/nginx/sites-enabled/onlyoffice
> + rm -f '/etc/nginx/conf.d/*.conf'
> + service nginx restart
>  * Restarting nginx nginx                                                [ OK ]
> ++ head -n 1
> ++ grep -oP '\d+'
> ++ free -m
> + TOTAL_MEMORY=15993
> + MEMORY_REQUIREMENTS=12228
> + '[' 15993 -gt 12228 ']'
> + grep -q '[-]Xms1g' /etc/elasticsearch/jvm.options
> + sed -i s/-Xms1g/-Xms4g/ /etc/elasticsearch/jvm.options
> + grep -q '[-]Xmx1g' /etc/elasticsearch/jvm.options
> + sed -i s/-Xmx1g/-Xmx4g/ /etc/elasticsearch/jvm.options
> + '[' 10.0.15.101 ']'
> + DOCUMENT_SERVER_ENABLED=true
> + DOCUMENT_SERVER_HOST=10.0.15.101
> + DOCUMENT_SERVER_API_URL='\/ds-vpath'
> + '[' true == true ']'
> + '[' 10.0.15.0/24 ']'
> + '[' -z '' ']'
> ++ dig +short 10.0.15.101
> + check_ip_is_internal 10.0.15.0/24
> ++ sed -ne 's:^\([0-9]\+\)\.\([0-9]\+\)\.\([0-9]\+\)\.\([0-9]\+\)/.*$:\1 \2 \3 \4:p'
> + IP=('10' '0' '15' '0')
> + local IP
> ++ sed -ne 's:*/\([0-9]\+\)\.\([0-9]\+\)\.\([0-9]\+\)\.\([0-9]\+\)$:\1 \2 \3 \4:p'
> + MASK=()
> + local MASK
> + '[' 0 -ne 4 ']'
> + BITCNT=('24')
> + local BITCNT
> + BITCNT=4294967040
> + (( I=0 ))
> + (( I<4 ))
> + MASK[$I]=255
> + (( I++  ))
> + (( I<4 ))
> + MASK[$I]=255
> + (( I++  ))
> + (( I<4 ))
> + MASK[$I]=255
> + (( I++  ))
> + (( I<4 ))
> + MASK[$I]=0
> + (( I++  ))
> + (( I<4 ))
> + NETWORK=()
> + local NETWORK
> + (( I=0 ))
> + (( I<4 ))
> + NETWORK[$I]=10
> + (( I++  ))
> + (( I<4 ))
> + NETWORK[$I]=0
> + (( I++  ))
> + (( I<4 ))
> + NETWORK[$I]=15
> + (( I++  ))
> + (( I<4 ))
> + NETWORK[$I]=0
> + (( I++  ))
> + (( I<4 ))
> ++ sed -ne 's:^\([0-9]\+\)\.\([0-9]\+\)\.\([0-9]\+\)\.\([0-9]\+\)$:\1 \2 \3 \4:p'
> ++ echo ''
> + INIP=()
> + local INIP
> + (( I=0 ))
> + (( I<4 ))
> /app/run-community-server.sh: line 207: & 255 : syntax error: operand expected (error token is "& 255 ")
> + '[' 10.0.15.101 == onlyoffice-document-server ']'
> + '[' 10.0.12.10 '!=' localhost ']'
> + '[' 10.0.12.10 '!=' 127.0.0.1 ']'
> + MYSQL_SERVER_EXTERNAL=true
> + '[' 80 ']'
> + CONTROL_PANEL_ENABLED=true
> + set +x
> ++ date +%Y-%m-%dT%H:%M:%S
> + MAIL_IMAPSYNC_START_DATE=2024-11-20T13:58:19
> + sed 's_\(\"ImapSyncStartDate":\).*,_\1 "2024-11-20T13:58:19",_' -i /etc/onlyoffice/communityserver/mail.production.json
> + sed '/mail\.imap-sync-start-date/s/value="\S*"/value="2024-11-20T13:58:19"/g' -i /var/www/onlyoffice/WebStudio/web.appsettings.config
> + REDIS_SERVER_HOST=
> + REDIS_SERVER_CACHEPORT=6379
> + REDIS_SERVER_PASSWORD=
> + REDIS_SERVER_SSL=false
> + REDIS_SERVER_DATABASE=0
> + REDIS_SERVER_CONNECT_TIMEOUT=5000
> + REDIS_SERVER_EXTERNAL=false
> + REDIS_SERVER_SYNC_TIMEOUT=60000
> + '[' false == false ']'
> + '[' -e /etc/redis/redis.conf ']'
> + sed -i 's/bind .*/bind 127.0.0.1/g' /etc/redis/redis.conf
> + ELASTICSEARCH_SERVER_HOST=10.0.15.102
> + ELASTICSEARCH_SERVER_HTTPPORT=9200
> + grep -q '<section name="elastic" type="ASC.ElasticSearch.Config.ElasticSection, ASC.ElasticSearch" />' /var/www/onlyoffice/WebStudio/Web.config
> + '[' 10.0.15.102 ']'
> + sed -i '/<section name="redisCacheClient" type="StackExchange.Redis.Extensions.LegacyConfiguration.RedisCachingSectionHandler, StackExchange.Redis.Extensions.LegacyConfiguration" \/>/a <section name="elastic" type="ASC.ElasticSearch.Config.ElasticSection, ASC.ElasticSearch" \/>' /var/www/onlyoffice/WebStudio/Web.config
> + sed -i 's/<section name="elastic" type="ASC.ElasticSearch.Config.ElasticSection, ASC.ElasticSearch" \/>/    <section name="elastic" type="ASC.ElasticSearch.Config.ElasticSection, ASC.ElasticSearch" \/>/' /var/www/onlyoffice/WebStudio/Web.config
> + sed -i '/<section name="redisCacheClient" type="StackExchange.Redis.Extensions.LegacyConfiguration.RedisCachingSectionHandler, StackExchange.Redis.Extensions.LegacyConfiguration" \/>/a <section name="elastic" type="ASC.ElasticSearch.Config.ElasticSection, ASC.ElasticSearch" \/>' /var/www/onlyoffice/Services/TeamLabSvc/TeamLabSvc.exe.config
> + sed -i 's/<section name="elastic" type="ASC.ElasticSearch.Config.ElasticSection, ASC.ElasticSearch" \/>/    <section name="elastic" type="ASC.ElasticSearch.Config.ElasticSection, ASC.ElasticSearch" \/>/' /var/www/onlyoffice/Services/TeamLabSvc/TeamLabSvc.exe.config
> + '[' 9200 ']'
> + sed -i '/<\/configSections>/a <elastic scheme="http" host="10.0.15.102" port="9200" \/>' /var/www/onlyoffice/WebStudio/Web.config
> + sed -i 's/<elastic scheme="http" host="10.0.15.102" port="9200" \/>/  <elastic scheme="http" host="10.0.15.102" port="9200" \/>/' /var/www/onlyoffice/WebStudio/Web.config
> + sed -i '/<\/configSections>/a <elastic scheme="http" host="10.0.15.102" port="9200" \/>' /var/www/onlyoffice/Services/TeamLabSvc/TeamLabSvc.exe.config
> + sed -i 's/<elastic scheme="http" host="10.0.15.102" port="9200" \/>/  <elastic scheme="http" host="10.0.15.102" port="9200" \/>/' /var/www/onlyoffice/Services/TeamLabSvc/TeamLabSvc.exe.config
> + sed -i 's/"Host": "127.0.0.1"/"Host": "10.0.15.102"/g' /etc/onlyoffice/communityserver/elastic.production.json
> + sed -i 's/"Port": "9200"/"Port": "9200"/g' /etc/onlyoffice/communityserver/elastic.production.json
> + '[' true == false ']'
> + mysqladmin shutdown
> mysqladmin: connect to server at '10.0.12.10' failed
> error: 'Access denied for user 'root'@'10.0.15.100' (using password: NO)'
> + systemctl disable mysql.service
> Synchronizing state of mysql.service with SysV service script with /lib/systemd/systemd-sysv-install.
> Executing: /lib/systemd/systemd-sysv-install disable mysql
> Removed /etc/systemd/system/multi-user.target.wants/mysql.service.
> + mysql_check_connection
> + mysqladmin --defaults-extra-file=/etc/mysql/conf.d/client.cnf ping
> mysqld is alive
> ++ mysql_scalar_exec 'SELECT SCHEMA_NAME FROM information_schema.SCHEMATA WHERE SCHEMA_NAME='\''onlyoffice_db'\''' opt_ignore_db_name
> ++ local queryResult=
> ++ '[' opt_ignore_db_name == opt_ignore_db_name ']'
> +++ mysql --defaults-extra-file=/etc/mysql/conf.d/client.cnf --skip-column-names -e 'SELECT SCHEMA_NAME FROM information_schema.SCHEMATA WHERE SCHEMA_NAME='\''onlyoffice_db'\'''
> ++ queryResult=onlyoffice_db
> ++ echo onlyoffice_db
> + DB_IS_EXIST=onlyoffice_db
> ++ mysql_scalar_exec 'SELECT DEFAULT_CHARACTER_SET_NAME FROM information_schema.SCHEMATA WHERE SCHEMA_NAME='\''onlyoffice_db'\''' opt_ignore_db_name
> +++ mysql --defaults-extra-file=/etc/mysql/conf.d/client.cnf --skip-column-names -e 'SELECT DEFAULT_CHARACTER_SET_NAME FROM information_schema.SCHEMATA WHERE SCHEMA_NAME='\''onlyoffice_db'\'''
> ++ queryResult=utf8mb4
> ++ echo utf8mb4
> + DB_CHARACTER_SET_NAME=utf8mb4
> ++ mysql_scalar_exec 'SELECT DEFAULT_COLLATION_NAME FROM information_schema.SCHEMATA WHERE SCHEMA_NAME='\''onlyoffice_db'\''' opt_ignore_db_name
> +++ mysql --defaults-extra-file=/etc/mysql/conf.d/client.cnf --skip-column-names -e 'SELECT DEFAULT_COLLATION_NAME FROM information_schema.SCHEMATA WHERE SCHEMA_NAME='\''onlyoffice_db'\'''
> ++ queryResult=utf8mb4_0900_ai_ci
> ++ echo utf8mb4_0900_ai_ci
> + DB_COLLATION_NAME=utf8mb4_0900_ai_ci
> ++ mysql_scalar_exec 'SELECT COUNT(*) FROM information_schema.tables WHERE table_schema='\''onlyoffice_db'\'''
> ++ '[' '' == opt_ignore_db_name ']'
> +++ mysql --defaults-extra-file=/etc/mysql/conf.d/client.cnf --skip-column-names -D onlyoffice_db -e 'SELECT COUNT(*) FROM information_schema.tables WHERE table_schema='\''onlyoffice_db'\'''
> ++ queryResult=0
> ++ echo 0
> + DB_TABLES_COUNT=0
> + '[' -z onlyoffice_db ']'
> + '[' utf8mb4 '!=' utf8 ']'
> + mysql_scalar_exec 'ALTER DATABASE onlyoffice_db CHARACTER SET utf8 COLLATE utf8_general_ci'
> ++ mysql --defaults-extra-file=/etc/mysql/conf.d/client.cnf --skip-column-names -D onlyoffice_db -e 'ALTER DATABASE onlyoffice_db CHARACTER SET utf8 COLLATE utf8_general_ci'
> + queryResult=
> + echo
> + change_connections default /var/www/onlyoffice/WebStudio/web.connections.config
> + set +x
> + change_connections teamlabsite /var/www/onlyoffice/WebStudio/web.connections.config
> + set +x
> + change_connections default /var/www/onlyoffice/Services/TeamLabSvc/TeamLabSvc.exe.config
> + set +x
> + change_connections default /var/www/onlyoffice/Services/Jabber/ASC.Xmpp.Server.Launcher.exe.config
> + set +x
> + change_connections default /var/www/onlyoffice/ApiSystem/Web.config
> + set +x
> + set +x
> + '[' 0 -eq 0 ']'
> + mysql_batch_exec /var/www/onlyoffice/Sql/onlyoffice.sql
> ERROR 1067 (42000) at line 2232: Invalid default value for 'creationDate'
> + mysql_batch_exec /var/www/onlyoffice/Sql/onlyoffice.data.sql
> ERROR 1146 (42S02) at line 2303: Table 'onlyoffice_db.tenants_tenants' doesn't exist
> + mysql_batch_exec /var/www/onlyoffice/Sql/onlyoffice.resources.sql
> /app/run-community-server.sh: line 561: /var/www/onlyoffice/Sql/onlyoffice.resources.sql: No such file or directory
> + mysql_scalar_exec 'DELETE FROM webstudio_settings WHERE id='\''5C699566-34B1-4714-AB52-0E82410CE4E5'\'';'
> ++ mysql --defaults-extra-file=/etc/mysql/conf.d/client.cnf --skip-column-names -D onlyoffice_db -e 'DELETE FROM webstudio_settings WHERE id='\''5C699566-34B1-4714-AB52-0E82410CE4E5'\'';'
> ERROR 1146 (42S02) at line 1: Table 'onlyoffice_db.webstudio_settings' doesn't exist
> + queryResult=
> + echo
> + cp /etc/nginx/includes/onlyoffice-communityserver-common.conf.template /app/config/nginx/prepare-onlyoffice
> + sed -i 1d /etc/logrotate.d/nginx
> + sed '1 i\/var/log/nginx/*.log /var/log/onlyoffice/nginx.*.log {' -i /etc/logrotate.d/nginx
> + sed 's,{{DOCKER_APP_SUBNET}},10.0.15.0/24,' -i /app/config/nginx/prepare-onlyoffice
> + sed '/files\.docservice\.secret/s!\(value\s*=\s*\"\)[^\"]*\"!\1XXXXXXXXXXX\"!' -i /var/www/onlyoffice/WebStudio/web.appsettings.config
> + sed '/files\.docservice\.secret.header/s!\(value\s*=\s*\"\)[^\"]*\"!\1AuthorizationJwt\"!' -i /var/www/onlyoffice/WebStudio/web.appsettings.config
> + sed '/files\.docservice\.secret/s!\(value\s*=\s*\"\)[^\"]*\"!\1XXXXXXXXXXX\"!' -i /var/www/onlyoffice/Services/TeamLabSvc/TeamLabSvc.exe.config
> + sed '/files\.docservice\.secret.header/s!\(value\s*=\s*\"\)[^\"]*\"!\1AuthorizationJwt\"!' -i /var/www/onlyoffice/Services/TeamLabSvc/TeamLabSvc.exe.config
> + cp /etc/nginx/includes/onlyoffice-communityserver-proxy-to-documentserver.conf.template /etc/nginx/includes/onlyoffice-communityserver-proxy-to-documentserver.conf
> + sed 's,{{DOCUMENT_SERVER_HOST_ADDR}},http:\/\/10.0.15.101,' -i /etc/nginx/includes/onlyoffice-communityserver-proxy-to-documentserver.conf
> + sed '/files\.docservice\.url\.internal/s!\(value\s*=\s*\"\)[^\"]*\"!\1http:\/\/10.0.15.101\/\"!' -i /var/www/onlyoffice/WebStudio/web.appsettings.config
> + sed '/files\.docservice\.url\.public/s!\(value\s*=\s*\"\)[^\"]*\"!\1\/ds-vpath\/\"!' -i /var/www/onlyoffice/WebStudio/web.appsettings.config
> + sed '/files\.docservice\.url\.internal/s!\(value\s*=\s*\"\)[^\"]*\"!\1http:\/\/10.0.15.101\/\"!' -i /var/www/onlyoffice/Services/TeamLabSvc/TeamLabSvc.exe.config
> + sed '/files\.docservice\.url\.public/s!\(value\s*=\s*\"\)[^\"]*\"!\1\/ds-vpath\/\"!' -i /var/www/onlyoffice/Services/TeamLabSvc/TeamLabSvc.exe.config
> + '[' -n 10.0.15.0/24 ']'
> + '[' -n '' ']'
> + '[' false == true ']'
> + cp /etc/nginx/includes/onlyoffice-communityserver-proxy-to-controlpanel.conf.template /etc/nginx/includes/onlyoffice-communityserver-proxy-to-controlpanel.conf
> + sed 's,{{CONTROL_PANEL_HOST_ADDR}},10.0.15.103,' -i /etc/nginx/includes/onlyoffice-communityserver-proxy-to-controlpanel.conf
> + sed 's,{{SERVICE_SSO_AUTH_HOST_ADDR}},10.0.15.103,' -i /etc/nginx/includes/onlyoffice-communityserver-proxy-to-controlpanel.conf
> + sed '/web\.controlpanel\.url/s/\(value\s*=\s*\"\)[^\"]*\"/\1\/controlpanel\/\"/' -i /var/www/onlyoffice/WebStudio/web.appsettings.config
> + sed '/web\.controlpanel\.url/s/\(value\s*=\s*\"\)[^\"]*\"/\1\/controlpanel\/\"/' -i /var/www/onlyoffice/Services/TeamLabSvc/TeamLabSvc.exe.config
> + '[' SERVER == SERVER ']'
> ++ seq 1 1
> + for serverID in $(seq 1 ${APP_MONOSERVE_COUNT})
> + '[' 1 == 1 ']'
> + sed '/web.warmup.count/s/value=\"\S*\"/value=\"1\"/g' -i /var/www/onlyoffice/WebStudio/web.appsettings.config
> + sed '/web.warmup.domain/s/value=\"\S*\"/value=\"localhost\/warmup\"/g' -i /var/www/onlyoffice/WebStudio/web.appsettings.config
> + sed 's^\(machine_key\)\s*=.*^\1 = XXXXXXXXXXX^g' -i /var/www/onlyoffice/Services/TeamLabSvc/radicale.config
> + binDirs=("$APP_APISYSTEM_DIR" "$APP_SERVICES_DIR" "$APP_ROOT_DIR" "$APP_CONFIG_DIR")
> + for i in "${!binDirs[@]}"
> + find /var/www/onlyoffice/ApiSystem -type f -name '*.[cC]onfig' -exec sed -i '/core.\machinekey/s_\(value\s*=\s*"\)[^"]*"_\1XXXXXXXXXXX"_' '{}' ';'
> + find /var/www/onlyoffice/ApiSystem -type f -name '*.json' -exec sed -i 's_\("core.machinekey":\|"machinekey":\).*,_\1 "XXXXXXXXXXX",_' '{}' ';'
> + find /var/www/onlyoffice/Services -type f -name '*.[cC]onfig' -exec sed -i '/core.\machinekey/s_\(value\s*=\s*"\)[^"]*"_\1XXXXXXXXXXX"_' '{}' ';'
> + find /var/www/onlyoffice/Services -type f -name '*.json' -exec sed -i 's_\("core.machinekey":\|"machinekey":\).*,_\1 "XXXXXXXXXXX",_' '{}' ';'
> + find /var/www/onlyoffice/WebStudio -type f -name '*.[cC]onfig' -exec sed -i '/core.\machinekey/s_\(value\s*=\s*"\)[^"]*"_\1XXXXXXXXXXX"_' '{}' ';'
> + find /var/www/onlyoffice/WebStudio -type f -name '*.json' -exec sed -i 's_\("core.machinekey":\|"machinekey":\).*,_\1 "XXXXXXXXXXX",_' '{}' ';'
> + find /etc/onlyoffice/communityserver -type f -name '*.[cC]onfig' -exec sed -i '/core.\machinekey/s_\(value\s*=\s*"\)[^"]*"_\1XXXXXXXXXXX"_' '{}' ';'
> + find /etc/onlyoffice/communityserver -type f -name '*.json' -exec sed -i 's_\("core.machinekey":\|"machinekey":\).*,_\1 "XXXXXXXXXXX",_' '{}' ';'
> + continue
> + sed 's/{{APP_NIGNX_KEEPLIVE}}/32/g' -i /app/config/nginx/prepare-onlyoffice
> + bash -c 'echo "onlyoffice ALL=(ALL) NOPASSWD: /usr/sbin/service" | (EDITOR="tee -a" visudo)'
> + systemctl enable redis-server.service
> Synchronizing state of redis-server.service with SysV service script with /lib/systemd/systemd-sysv-install.
> Executing: /lib/systemd/systemd-sysv-install enable redis-server
> + service redis-server start
> Starting redis-server: redis-server.
> + redis-cli config set save ''
> OK
> + redis-cli config rewrite
> OK
> + redis-cli flushall
> OK
> + service redis-server stop
> Stopping redis-server: redis-server.
> + '[' SERVER == SERVICES ']'
> + systemctl enable monoserveApiSystem.service
> ++ seq 1 1
> + index=1
> + '[' 1 == 1 ']'
> + index=
> + systemctl enable monoserve.service
> + chown -R onlyoffice:onlyoffice /var/log/onlyoffice
> + chown -R onlyoffice:onlyoffice /var/www/onlyoffice/DocumentServerData
> ++ ls -alhd /var/www/onlyoffice/Data
> ++ awk '{ print $3 }'
> + '[' onlyoffice '!=' onlyoffice ']'
> + '[' '!' -d /var/www/onlyoffice/Data/Index/v7.16.3 ']'
> + mkdir -p /var/log/onlyoffice//Index
> + mkdir -p /var/www/onlyoffice/Data/Index/v7.16.3
> ++ ls -alhd /var/www/onlyoffice/Data/Index/v7.16.3
> + '[' elasticsearch '!=' elasticsearch ']'
> + chown -R elasticsearch:elasticsearch /var/log/onlyoffice//Index
> + dpkg -l
> + grep -q onlyoffice-xmppserver
> + sed '/web\.talk/s/value=\"\S*\"/value=\"true\"/g' -i /var/www/onlyoffice/WebStudio/web.appsettings.config
> + sed '/web\.chat/s/value=\"\S*\"/value=\"false\"/g' -i /var/www/onlyoffice/WebStudio/web.appsettings.config
> + systemctl stop onlyofficeRadicale
> System has not been booted with systemd as init system (PID 1). Can't operate.
> Failed to connect to bus: Host is down
> + systemctl stop onlyofficeTelegram
> + systemctl stop onlyofficeSocketIO
> + systemctl stop onlyofficeThumb
> + systemctl stop onlyofficeFeed
> + systemctl stop onlyofficeIndex
> + systemctl stop onlyofficeJabber
> + systemctl stop onlyofficeMailAggregator
> + systemctl stop onlyofficeMailWatchdog
> + systemctl stop onlyofficeMailCleaner
> + systemctl stop onlyofficeMailImap
> + systemctl stop onlyofficeNotify
> + systemctl stop onlyofficeBackup
> + systemctl stop onlyofficeStorageMigrate
> + systemctl stop onlyofficeStorageEncryption
> + systemctl stop onlyofficeUrlShortener
> + systemctl stop onlyofficeThumbnailBuilder
> + systemctl stop onlyofficeFilesTrashCleaner
> + systemctl stop god
> + systemctl enable god
> + systemctl stop elasticsearch
> + systemctl stop redis-server
> + systemctl stop nginx
> + systemctl stop monoserveApiSystem.service
> ++ seq 1 1
> + index=1
> + '[' 1 == 1 ']'
> + index=
> + systemctl stop monoserve.service
> + systemctl enable onlyofficeRadicale.service
> + systemctl enable onlyofficeTelegram.service
> + systemctl enable onlyofficeSocketIO.service
> + systemctl enable onlyofficeThumb.service
> + systemctl enable onlyofficeFeed.service
> + systemctl enable onlyofficeIndex.service
> + systemctl enable onlyofficeJabber.service
> + systemctl enable onlyofficeMailAggregator.service
> + systemctl enable onlyofficeMailWatchdog.service
> + systemctl enable onlyofficeMailCleaner.service
> + systemctl enable onlyofficeMailImap.service
> + systemctl enable onlyofficeNotify.service
> + systemctl enable onlyofficeBackup.service
> + systemctl enable onlyofficeStorageMigrate.service
> + systemctl enable onlyofficeStorageEncryption.service
> + systemctl enable onlyofficeUrlShortener.service
> + systemctl enable onlyofficeThumbnailBuilder.service
> + systemctl enable onlyofficeFilesTrashCleaner.service
> + mv /app/config/nginx/prepare-onlyoffice /etc/nginx/sites-enabled/onlyoffice
> + service nginx stop
>  * Stopping nginx nginx                                                  [ OK ]
> + systemctl enable nginx.service
> Synchronizing state of nginx.service with SysV service script with /lib/systemd/systemd-sysv-install.
> Executing: /lib/systemd/systemd-sysv-install enable nginx
> ++ ps auxf
> ++ grep cron
> ++ grep -v grep
> ++ awk '{print $2}'
> + PID=
> + service elasticsearch stop
>  * Stopping Elasticsearch Server                                         [ OK ]
> + systemctl disable elasticsearch.service
> Synchronizing state of elasticsearch.service with SysV service script with /lib/systemd/systemd-sysv-install.
> Executing: /lib/systemd/systemd-sysv-install disable elasticsearch
> + rm -f /usr/lib/systemd/system/elasticsearch.service
> + rm -f /etc/init.d/elasticsearch
> + '[' -n '' ']'
> + rm -dfr '/tmp/onlyoffice*'
> + rm -dfr '/var/run/onlyoffice/*'
> + rm -dfr '/var/cache/nginx/onlyoffice/*'
> + exec /lib/systemd/systemd
> systemd 249.11-0ubuntu3.12 running in system mode (+PAM +AUDIT +SELINUX +APPARMOR +IMA +SMACK +SECCOMP +GCRYPT +GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBFDISK +PCRE2 -PWQUALITY -P11KIT -QRENCODE +BZIP2 +LZ4 +XZ +ZLIB +ZSTD -XKBCOMMON +UTMP +SYSVINIT default-hierarchy=unified)
> Detected virtualization docker.
> Detected architecture x86-64.
> Welcome to Ubuntu 22.04.4 LTS!
> Queued start job for default target Graphical Interface.
> [  OK  ] Reached target Path Units.
> [  OK  ] Reached target Slice Units.
> [  OK  ] Reached target Swaps.
> [  OK  ] Listening on Syslog Socket.
> [  OK  ] Listening on Journal Audit Socket.
> [  OK  ] Listening on Journal Socket (/dev/log).
> [  OK  ] Listening on Journal Socket.
> [  OK  ] Reached target Socket Units.
>          Starting Remount Root and Kernel File Systems...
>          Starting Create Static Device Nodes in /dev...
>          Starting Journal Service...
> [  OK  ] Finished Remount Root and Kernel File Systems.
> [  OK  ] Finished Create Static Device Nodes in /dev.
> [  OK  ] Reached target Preparation for Local File Systems.
> [  OK  ] Reached target Local File Systems.
>          Starting Enable support fo…l executable binary formats...
> [  OK  ] Finished Enable support fo…nal executable binary formats.
> [  OK  ] Started Journal Service.
>          Starting Create Volatile Files and Directories...
> [  OK  ] Finished Create Volatile Files and Directories.
> [  OK  ] Reached target System Initialization.
> [  OK  ] Started Run certbot twice daily.
> [  OK  ] Started Daily rotation of log files.
> [  OK  ] Started Daily Cleanup of Temporary Directories.
> [  OK  ] Reached target Basic System.
> [  OK  ] Reached target Timer Units.
> [  OK  ] Listening on D-Bus System Message Bus Socket.
> [  OK  ] Started Regular background program processing daemon.
> [  OK  ] Started Save initial kernel messages after boot.
>          Starting God Service...
>          Starting LSB: Mono XSP4...
>          Starting MySQL Community Server...
>          Starting A high performanc… and a reverse proxy server...
>          Starting ONLYOFFICE SsoAuth Service...
>          Starting ONLYOFFICE Thumb Service...
>          Starting Advanced key-value store...
>          Starting System Logging Service...
> [  OK  ] Started System Logging Service.
> [  OK  ] Started ONLYOFFICE SsoAuth Service.
> [  OK  ] Started ONLYOFFICE Thumb Service.
> [  OK  ] Started A high performance…er and a reverse proxy server.
> [  OK  ] Started LSB: Mono XSP4.
> [  OK  ] Started Advanced key-value store.
> [  OK  ] Started God Service.
> [  OK  ] Started MySQL Community Server.
>          Starting FastCGI Mono server...
>          Starting Start ONLYOFFICE Backup Service...
>          Starting ONLYOFFICE Feed Service...
>          Starting ONLYOFFICE FilesTrashCleaner Service...
>          Starting Start ONLYOFFICE Index Service...
>          Starting ONLYOFFICE Jabber Service...
>          Starting ONLYOFFICE MailAggregator Service...
>          Starting ONLYOFFICE MailCleaner Service...
>          Starting ONLYOFFICE MailImap Service...
>          Starting ONLYOFFICE MailWatchdog Service...
>          Starting ONLYOFFICE Notify Service...
>          Starting ONLYOFFICE Radicale Service...
>          Starting ONLYOFFICE SocketIO Service...
>          Starting Start ONLYOFFICE StorageEncryption Service...
>          Starting Start ONLYOFFICE StorageMigrate Service...
>          Starting ONLYOFFICE Telegram Service...
>          Starting ONLYOFFICE ThumbnailBuilder Service...
>          Starting ONLYOFFICE UrlShortener Service...
>          Starting ONLYOFFICE WebDav Service...
> [  OK  ] Started FastCGI Mono server.
> [  OK  ] Started ONLYOFFICE Radicale Service.
> [  OK  ] Started ONLYOFFICE SocketIO Service.
> [  OK  ] Started ONLYOFFICE UrlShortener Service.
> [  OK  ] Started ONLYOFFICE WebDav Service.
> [  OK  ] Started Start ONLYOFFICE Backup Service.
> [  OK  ] Started ONLYOFFICE Notify Service.
> [  OK  ] Started Start ONLYOFFICE StorageEncryption Service.
> [  OK  ] Started ONLYOFFICE FilesTrashCleaner Service.
> [  OK  ] Started ONLYOFFICE Feed Service.
> [  OK  ] Started Start ONLYOFFICE Index Service.
> [  OK  ] Started ONLYOFFICE Jabber Service.
> [  OK  ] Started Start ONLYOFFICE StorageMigrate Service.
> [  OK  ] Started ONLYOFFICE Telegram Service.
> [  OK  ] Started ONLYOFFICE ThumbnailBuilder Service.
> [  OK  ] Started ONLYOFFICE MailCleaner Service.
> [  OK  ] Stopped ONLYOFFICE FilesTrashCleaner Service.
> [  OK  ] Started ONLYOFFICE MailImap Service.
> [  OK  ] Started ONLYOFFICE MailWatchdog Service.
> [  OK  ] Started ONLYOFFICE MailAggregator Service.
> [  OK  ] Reached target Multi-User System.
> [  OK  ] Reached target Graphical Interface.
All looks fine in the logs, but when I try to catch the community server:
Someone had a similar issue?
Best regards,
And after some minutes, the page changes to:
Hello @simpleacc,
We recommend you use the script installation guide for Docker. The link is provided below:
https://helpcenter.onlyoffice.com/installation/workspace-install-docker.aspx
If you would like to install the solution using your own parameters, a complete list of all available parameters for automatic Docker installation is available at the following link:
https://helpcenter.onlyoffice.com/installation/workspace-install-docker-parameters.aspx
