ONLYOFFICE API documentation error
Do you want to: Report a bug
ONLYOFFICE Api Documentation - Config
macrosMode Defines the macro run mode. Can take the following values:
  • disable - don’t run at all;
  • enable - run all macros automatically;
  • warn - warn about macros and ask permission to run.
The default value is warn.
boolean
true
macrosmode type is Boolean , How to use enable
OS: irrelevant
Browser version: irrelevant
Hello @fuxiaoyun
Thank you for pointing us to this situation. We will fix description shortly.
Thank you one more time.
