ONLYOFFICE Docs v7.3 released: enhanced forms, SmartArt, new security settings, Watch Window, and more
ONLYOFFICE 7.3 websocket path changed
Thanks for the new ONLYOFFICE 7.3 and the nice new features.
We just test the new version. We found a issue regarding the proxy configuration.
The path of the websockets seems to be changed so that your example does not match the current situation:
This change also breaks the current reverse proxy configurations that based on your old/current examples.
Is it possible to change this path back to /websocket?
Or have we made a mistake (we use Docker)?
Best regards
Uli
There is also a thread about this on GitHub, is the upgrade process that needs to be followed documented anywhere?
Same issue, had to rollback to previous documentserver image (using ds on docker with https/http proxy).
Hi @uwohlfeil @Viis @chris,
We are currently investigating the ways to adjust the proxy configuration examples. Sorry for the inconvenience. I will let you know immediately when the fix is ready.
BTW we have an update, it seems you can temporarily fix the issue using this example:
Replace the line
ProxyPassMatch /(.*)(\/websocket)$ "ws://${OO_ADDRESS}/$1$2"
with
RewriteCond %{HTTP:Upgrade} websocket [NC]
RewriteCond %{HTTP:Connection} upgrade [NC]
RewriteRule ^/?(.*) "wss://${OO_ADDRESS}/$1" [P,L]
and check the results.
@Carl Thank you for the example. It seems to work.
Why was this adjusted?
I ask this because now all existing installations with reverse proxy must be adjusted.
In 7.3 we changed the websocket library from sockjs to socket.io
https://github.com/ONLYOFFICE/DocumentServer/blob/master/CHANGELOG.md#back-end
That’s why the websocket path looks differently now. We will correct the proxy configuration examples.
Hi, do you have the nginx configuration snippet to use for proxy setup?
Hello @zaggynl,
Do you encounter websocket errors when using nginx as a proxy in front of the Document Server?
Yes:
GET wss://office.hostname.tld/7.3.0-184/doc/3101420063/c/?EIO=4&transport=websocket [HTTP/1.1 400 Bad Request 259ms]
Snippet in Nginx I use:
< SSL bit>
< robots bit>
location / {
proxy_pass http://xx.xx.xx.xx:80;
proxy_http_version 1.1;
proxy_set_header Host $host;
proxy_set_header X-Real-IP $remote_addr;
proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for;
proxy_set_header X-Forwarded-Proto https;
You need to add the Upgrade and Connection headers to proxy the websocket connection correctly.
I have just tested nginx proxy using this config upstream docservice { server my-document-server-address;}map $http_host - Pastebin.com (based on https://github.com/ONLYOFFICE/document-server-proxy/blob/master/nginx/proxy-https-to-http.conf) and there were no websocket errors.
Thanks for the reply!
What does $proxy_connection in
proxy_set_header Connection $proxy_connection;
stand for? It is unrecognized on nginx -t check.\
Edit:
Disregard, forgot to add the
        map $http_upgrade $proxy_connection {
          default upgrade;
          "" close;
bit under http level, my nextcloud/onlyoffice is now working again with v7.3!
hi @Carl ,the same problem ,but , i useing onlyoffce community install with linux centos ,not docker version ,i has change my docserver local.json ,and set up token inbody:true ,so restart docserver,but open again my html ,receice this message in my broser debug model.
show my docserver err log :
show my nginx conf :
Please use the configuration examples given above. Note that they are not for nginx.conf, but for the server blocks that you set up for the Document Server.
OK,thank you answer an question ,this problm has deatail :heart_eyes:
