Below is a screenshot of the problem
In word, it can be filled in by the following characters
Replacing it with a comma fills the part but not tightly
I think this is a paragraph bug, Is there any way to fix this quickly?
Looking forward to your reply.
Hello @GGbeng1
First of all, please let me know version of Document Server that is used in these screenshots.
Additionally, I’d kindly ask you to provide a test document in which we can analyze this issue.
I’m using the latest version of onlyoffice, and below is the text that can trigger the bug
你好年后十大还是觉得哈看见了暗杀教科书的暗红色的卡号是的卡上卡仕达说的话,出发问题、你好、你好、你好、你好、你好、你好。
I don’t know why the Don is causing this problem, is there a way to fix it temporarily
Thank you for sharing a demo file. We are checking the situation.
We have registered a bug based on the behavior with Don symbol. Thank you for reporting it and sorry for any inconvenience.
As for the workaround: you can simply replace these characters with regular commas.
Hello, this issue is also created on github #68658, which version will fix this issue? At present, this problem has been plaguing the normal use of Chinese writing
Unfortunately, I do not have such information. Once this issue is fixed, we will surely notify you.
