On Device open-from-folder capability appears to have been removed in v8.2.2. Is there any additional guidance or rationale available around this change?
Am inferring the alternative suggested method is Import File via the UI’s “+” menu. This appears to create/store/duplicate documents in an app cache, rather than editing the file on the file system. Personally have no desire to use (any) cloud service and so I sync phone documents via p2p with other network devices. This pattern is now broken, because the file on the device filesystem is not actually updated. Attempting to use the menu’s move feature creates a new ‘copy’ file on the drive because there’s a name collision with the file that’s there (the one I wanted to edit directly) with OO. Basically a mess.
Any possibility this change might be reversed? This is the exact reason that I left WPS Office. Switching back to v8.2.0 for now.
Device: Samsung S20
OS version: 13
App version: 8.2.2
Mode: On Device
I am checking out this decision and I will provide a feedback.
In the meantime, as far as I know, you still can open documents from local storage directly from it with Open in or similar option. Do I understand that your usage scenario was about opening the files directly from Documents app, for instance, from the list of recent files?
UPD: I was informed that the issue with missing plus sign to add files from local storage is a known issue. It planned to be brought back to the toolbar in next major version. Anyway, I will inform you once the version with fix is released.
Only since you happened to specifically mention the “plus” button… For clarity, the functionality I was referring to is/was the “folder” icon previously available, which opened access to the actual device filesystem. The “plus” sign only ever seems to have provided the “import” functionality, which has the app cache / duplication issue mentioned previously.
Thanks for the feedback @kjdfngrt. I, indeed, understand. You still can utilize approach I’ve mentioned too:
As for @userOO’s question: I was referring to 8.3 mostly. I don’t have exact timeline, but I believe it is about a couple of months tops. Anyway, I will keep you posted.
Hi @Constantine,
In Android 8.3.0 I am again seeing the filesystem ‘folder’ icon within the On Device section, and am able to open files from the filesystem navigator menu that opens from there.
This addresses all of my originally reported issues. Thanks so much to you and the team for tackling this!!
