Hi Everyone. We’re running the OnlyOffice 15.0 module on Odoo 15 CE. Everything’s setup as instructed on both sides. Docserver is running perfectly with other apps such as Nextcloud. When clicking on a PDF or DOCX attachment in Odoo, we’re experiencing the “Download failed” popup in the browser with the following logs:
OnlyOffice Converter – out.log:
2023-12-10T08:20:49.711] [ERROR] [localhost] [8864c4582ab35193902b2ccfe343f3309d0d99233000] [9] nodeJS - error downloadFile:url=https://odoo-server/onlyoffice/file/content/8864?oo_security_token=eyJhbGciOiJIUzI1NiIsInR5cCI6IkpXVCJ9.eyJpZCI6OX0.77HMdvpnCI3NdumWP8Tf-1VB2nbRUbD33eDJIlB3MSU;attempt=1;code:undefined;connect:undefined Error: Error response: statusCode:500; headers:{“server”:“nginx/1.18.0”,“date”:“Sun, 10 Dec 2023 00:20:49 GMT”,“content-type”:“text/html;charset=utf-8”,“content-length”:“1810”,“connection”:“keep-alive”,“set-cookie”:[“frontend_lang=en_GB; Path=/”,“session_id=7474c96dd4fe46d662a4cbfc67703a675a95c143; Expires=Sat, 09-Mar-2024 00:20:49 GMT; Max-Age=7776000; HttpOnly; Path=/”]};
at Request.fResponse (/snapshot/server/build/server/Common/sources/utils.js)
at Request.emit (events.js:400:28)
at Request.onRequestResponse (/snapshot/server/build/server/Common/node_modules/request/request.js:1059:10)
at ClientRequest.emit (events.js:400:28)
at HTTPParser.parserOnIncomingClient (_http_client.js:647:27)
at HTTPParser.parserOnHeadersComplete (_http_common.js:127:17)
at TLSSocket.socketOnData (_http_client.js:515:22)
at TLSSocket.emit (events.js:400:28)
at addChunk (internal/streams/readable.js:293:12)
at readableAddChunk (internal/streams/readable.js:267:9)
at TLSSocket.Readable.push (internal/streams/readable.js:206:10)
at TLSWrap.onStreamRead (internal/stream_base_commons.js:188:23)
When directly accessing the URL above: https://odoo-server/onlyoffice/file/content/8864?oo_security_token=eyJhbGciOiJIUzI1NiIsInR5cCI6IkpXVCJ9.eyJpZCI6OX0.77HMdvpnCI3NdumWP8Tf-1VB2nbRUbD33eDJIlB3MSU
The browser will show a 500 error with the following output:
Traceback (most recent call last):
File “/usr/lib/python3/dist-packages/odoo/addons/base/models/ir_http.py”, line 237, in _dispatch
result = request.dispatch()
File “/usr/lib/python3/dist-packages/odoo/http.py”, line 815, in dispatch
r = self._call_function(**self.params)
File “/usr/lib/python3/dist-packages/odoo/http.py”, line 368, in _call_function
return checked_call(self.db, *args, **kwargs)
File “/usr/lib/python3/dist-packages/odoo/service/model.py”, line 94, in wrapper
return f(dbname, *args, **kwargs)
File “/usr/lib/python3/dist-packages/odoo/http.py”, line 357, in checked_call
result = self.endpoint(*a, **kw)
File “/usr/lib/python3/dist-packages/odoo/http.py”, line 921, in call
return self.method(*args, **kw)
File “/usr/lib/python3/dist-packages/odoo/http.py”, line 546, in response_wrap
response = f(*args, **kw)
File “/usr/lib/python3/dist-packages/odoo/addons/onlyoffice_odoo/controllers/controllers.py”, line 35, in onlyoffice_get_file_content
raise Exception(“expected JWT”)
Exception
The above exception was the direct cause of the following exception:
Exception: expected JWT
We tried disabling tokens in the local.json configuration and removed the JWT secret from the Odoo configuration. Accessing the URL above from a browser logged into Odoo results in a download (without the OnlyOffice interface). However, from a different machine, it displays a 500 error with the following in the Odoo log:
2023-12-10 03:05:42,669 1507395 ERROR odoo odoo.addons.http_routing.models.ir_http: 500 Internal Server Error:
File “/usr/lib/python3.9/base64.py”, line 43, in _bytes_from_decode_data
return memoryview(s).tobytes()
TypeError: memoryview: a bytes-like object is required, not ‘NoneType’
File “/usr/lib/python3/dist-packages/odoo/addons/onlyoffice_odoo/controllers/controllers.py”, line 41, in onlyoffice_get_file_content
content_base64 = base64.b64decode(content)
File “/usr/lib/python3.9/base64.py”, line 80, in b64decode
s = _bytes_from_decode_data(s)
File “/usr/lib/python3.9/base64.py”, line 45, in _bytes_from_decode_data
raise TypeError("argument should be a bytes-like object or ASCII "
Exception
TypeError: argument should be a bytes-like object or ASCII string, not ‘NoneType’
Odoo & OnlyOffice are running on the same machine, both behind a Nginx proxy. They are being accessed from a remote network. We tried running a bare minimum Nginx configuration with the same results.
Any ideas? Happy to assist with the debugging process, thanks!
