ONLYOFFICE Mobile: Documents / Projects / Web Editors
Device: Lenovo Chromebook Duet 11
OS version: 134
App version: 8.3.2
Mode: On Device
Additional information: When I type text with the device keyboard or the virtual keyboard (in tablet mode), nothing visible happen, the cursor does not move at all.
Hello @denezroazhon
Please specify how did you install the app on your Chromebook device. If possible, please record a video with on-screen keyboard that demonstrates the behavior to share.
Thank you very much Constantine. Sorry for this late response. I have installed OnlyOffice through the Playstore. Here is a video capture of the problem. When I type, nothing appears in the document.
Unfortunately, this requires authentication, I cannot access the video. Is it possible to share auth-less access or upload the video to any other cloud storage?
Here it IS : https://youtu.be/qxE1YWEMOLY
Thanks. On the initial screenshot I can see buttons to minimize, expand and close the window – are these available on your tablet? The video does not demonstrate them, but I am curious why they are there.
The buttons appear when the hardware keyboard is attached, and do not when it is detached and the virtual keyboard is used.
