Non way to change orientation
ONLYOFFICE Mobile: Documents
Report a bug
Device: Poco X3 pro smartphone
OS version: Android 13 / Miui 14
App version: all
Mode: On Device
My phone have orientation set to auto.
But each Time I create a New document (présentation), the slides are set horizontally.
Whatever is the orientation of the
phone, the slides are just Always horizontal and non way to set them vertically.
Hi @emaen :wave:
By default, slides have a 16:9 aspect ratio, which is standard for presentation display. However, if you prefer, you can adjust it to 4:3 in the settings.
Hi !
I know that !
That’s not the problem.
What I say is that slides created are ALWAYS landscape oriented ( 16:9 or 4:3, nevermind ).
There is no way to create portrait oriented slides.
@emaen
Understood. My fault :upside_down_face:
I’ll suggest this idea to our team. :handshake:
Hey @emaen
Thank you for taking the time to create the topic!
We have registered your suggestion.
Hi Nikolas,
Hi all of you !
It’s about 1 year ago, now, that I told you my concern with the impossibility to change orientation of slides in Presentation.
I’ve updated to the last android version of OnlyOffice today.
And it’s seems that there is still no support for creation of vertically oriented slides…
Do you plan to include it ?
