No way to turn off blinking text input cursor
For feature suggestions, describe the result you would like to achieve in detail:
I would like the app to respect system wide settings when it comes to the text input cursor. Right now it is blinking repeatedly, even though I have turned it off (solid line) in Windows 11, and all other apps respect this setting. Please, either give us an option to change this setting in the app, or - better yet - make it so that it respects the system-wide input setting, like all other Word clones do.
Type of installation of Workspace (docker, deb/rpm, exe): EXE
OS: Windows 11
Hello @PogoPhoenix
We are checking the situation. I’ll let you know we get any results.
We have registered an enhancement suggestion to make Desktop Editors to give consideration to the cursor blinking rate setting of the OS in our internal tracking system. It will be added in one of the future releases of the app.
Thank you for your suggestion.
