when I connect onlyoffice/documentserver from nextcloud(nc) .nc report a error “error while downloading the document file to be converted”
Without nextcloud ,I successfuly visited the onlyoffice/documentserver .And ds- example was normal after I change default.json (rejectUnauthorized": false).
I read the onlyoffice/documentserver’s error.log.
No such file “/var/www/onlyoffice/documentserver/sdkjs/common/libfont/wasm/engine.js”
The documentserver vervision is 7.1.1 , commumity ,docker
Hello @yanjunfeng
Please note that this version is outdated. I recommend updating it first and then checking the situation again.
If you face any issues, please provide any information about them as well as version of Nextcloud and the connector app.
Thank You!
I will try and feedback
Looking forward to your feedback.
I upgrade the onlyoffice (docker version).
/etc/onlyoffice/documentserver/default.json
rejectUnauthorized the value “true” change to false
nextcloud can connect to onlyoffice
Glad to know that it works.
